Trunk hitting body
Old Mar 16, 2016 | 01:45 PM
rsingerG37's Avatar
rsingerG37
Trunk hitting body
I just bought a 2012 certified g37 sedan and noticed the other day the paint is chipped on the area pictured below. It appears the trunk is hitting the body of the car. I saw a tsb for the trunk but it was for the trunk hitting the tail lights
Has anyone had this problem and did you find a solution?
Old Mar 16, 2016 | 02:52 PM
jfisher's Avatar
jfisher
I have the exact same issue. Was just going to have my Dad respray it at his body shop.
Old Mar 16, 2016 | 02:54 PM
ZahyMatar's Avatar
ZahyMatar
I've noticed the same thing on my 2012 Sedan.
Old Mar 16, 2016 | 03:02 PM
jomama22's Avatar
jomama22
There is a TSB out for this. Take it to the dealer. That should have been fixed by the dealer before you bought it. If it has any remaining full warranty they will cover it, if not, you may have to have a bit of jostle with them to cover it.
The trunk struts need to be adjusted.
Old Mar 16, 2016 | 03:14 PM
rsingerG37's Avatar
rsingerG37
Do you have that TSB? The only one i saw was for the trunk hitting the tail lights not the body.
Old Mar 16, 2016 | 03:19 PM
m3clubracer's Avatar
m3clubracer
My used car had the same but was hitting lights too. I used touch up paint and adjusted the stops on the trunk and remember not to slam the crap out of it. Problem solved.
Old Mar 16, 2016 | 03:46 PM
iCrap's Avatar
iCrap
Interesting... Mine doesn't do this.
Old Mar 16, 2016 | 03:54 PM
jomama22's Avatar
jomama22
It's the same TSB as the trunk one you saw, I didn't see you had posted about this but t already. It is in the same place as the TSB though so I'd assume it's the same issue.
Old Mar 16, 2016 | 09:32 PM
rsingerG37's Avatar
rsingerG37
Yeah it only mentioned the area by the lights, but i think that was also caused by the edge of the tail lights being to high.
Old Mar 16, 2016 | 10:45 PM
Epiphany's Avatar
Epiphany
Mine just got repainted under warranty a few weeks ago for doing this. No idea about TSB or anything.
Old Mar 16, 2016 | 11:07 PM
JSolo's Avatar
JSolo
Just say no!!!!!
This thread prompted me to check mine. Thankfully no damage. I'm guessing this results from improperly adjusted bumpers that came the trunk to slam into that part of the fender when slammed shut?
Old Mar 16, 2016 | 11:57 PM
rsingerG37's Avatar
rsingerG37
Yeah probably, although my stoppers are both fully extended.
Old Mar 18, 2016 | 12:09 AM
rsingerG37's Avatar
rsingerG37
Both my stoppers are fully extended and it makes the trunk hard to close. Should I adjust the position of the striker/latch?
Old Mar 18, 2016 | 02:57 PM
jomama22's Avatar
jomama22
You may be able to adjust the stops on the struts themselves. I think the TSB has some info on it.
Old Mar 18, 2016 | 04:00 PM
AUR11's Avatar
AUR11
My trunk hit and cracked the corner of my tail light.
