Starter question... It spins 😱
Old Mar 10, 2016 | 03:15 AM
cuco's Avatar
cuco
So today is the second day in a roll that my 08 g doesn't turn on right away. I press the button and I can only hear the starter spin but no crank. And shortly after a decently loud grind. Not as in starter flywheel grind. I try a couple more times and turns on right away. During the rest of the two day all worked fine. Any ideas on what I could be? I find it wierd that stater only spins and does not engage. Heeellllppppp... I order a new stater already but it won't be here until Monday and it was kind of expensive so if I can fix without replacing I can always return it. Please any insight??
Old Mar 11, 2016 | 12:12 AM
Was it really cold when you tried to start the car those two times?
Old Mar 12, 2016 | 03:37 PM
TVPostSound's Avatar
TVPostSound
The starter solenoid kicks the Bendix drive out to engage the flywheel.
Solenoid on the starter or a bad bendix drive is the issue.
Old Mar 14, 2016 | 03:36 AM
cuco's Avatar
cuco
just got a new starter I'm going to be installing Wednesday along with a new battery and test pipes lol and see if that solves the issue. thank you guys so much for the info
Old Mar 20, 2016 | 11:37 AM
SonicVQ's Avatar
SonicVQ
With the old starter out, take it apart and check for dried up grease.
I suspect if you clean and re-grease it will be fine.
Old Apr 8, 2016 | 12:17 AM
TVPostSound
Yeah, that was an old GM issue!!
jacob sami
Apr 11, 2016 07:24 PM
ZSpeedPerformance
Brakes/Suspension
Mar 16, 2016 11:05 AM
G37sGraphite
Mar 15, 2016 06:18 PM
Broski28
Intake and Exhaust
Mar 3, 2016 07:15 PM
