g37 14 pinn connector location
Old Jun 12, 2015 | 10:56 AM
zzww1251's Avatar
zzww1251
i borrowed a scan tool from a shop and i need to plug in the accessory plug into the g37 but dont know where it is. its not the obd2(under steering wheel area). any know where is the infiniti g37 connector that plugs into the nissan 14 pin connector?
thanks using a autel maxisys
Old Jun 21, 2015 | 03:06 PM
13_SkylineSedan's Avatar
13_SkylineSedan
Kinda quiet in here, huh? That's because I'm pretty sure the Autel Maxsys uses the OBD-2 connector to talk to our cars and the device's main cable should connect there.
From the MS908 manual:
Main Cable
The VCI device can be powered through the Main Cable when connected to an OBD II/EOBD compliant vehicle. The Main Cable connects the VCI device to the vehicle’s data link connector (DLC), through which the VCI device can transmit vehicle data to the MaxiSys display tablet.
Hopefully you figured it out and were able to get it to work...
SS2006
Aug 27, 2024 07:33 PM
Lt8Che
91
Apr 8, 2022 04:55 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
BANNISTER
Dec 10, 2015 04:14 PM
SS2006
Oct 20, 2015 11:02 AM
