Help with airbag light diagnostic
Old Jun 4, 2015 | 01:24 PM
tommiwan's Avatar
tommiwan
I recently removed my steering wheel to try and fix some steering wheel buttons that don't work. After putting things back together the airbag light is on. It flashes and I know that the flash pattern has a meaning. Can anyone help me with what this means?
One long flash, two short flashes, two short flashses, one long flash.
I haven't been able to find anything online that tells me what this means, or points me toward the actual error.
Old Jun 13, 2015 | 01:38 AM
crookncastle's Avatar
crookncastle
re-trace your steps and check if the airbag inflator connector on the drivers airbag fully engaged into the airbag unit. when you removed your steering wheel was your front tires in the straight forward centered position? sometimes the clock spring/cable reel is damaged due to the person who removed the steering wheel not centering the clock spring/cable reel when reinstalling the steering wheel.
Victory
17
Oct 27, 2022 03:45 PM
pcwd
Sep 15, 2015 10:06 PM
B Feelgood
Sep 13, 2015 05:56 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
Peepz
Sep 9, 2015 06:51 PM
