How to properly jump start 2011 Infiniti g37?
Step One
Park the booster vehicle close to the one that needs to be jumped, but not so close that the vehicles are touching in any way. You'll want to use a good set of jumper cables with thick wire and clean clamps. As you are hooking up the jumper cables, make sure they don't dangle into either engine compartment where they could get caught on moving parts (belts, fan, etc.). Turn off the ignition of both vehicles, set the parking brakes, and make sure that they are in either "Park" or "Neutral" depending on whether the vehicles have an automatic or manual transmission. Also, turn off all accessories like lights, radio and, if the vehicles are in a safe area, the hazard flashers.
Step Two
Begin the process by clamping one of the positive jumper cable ends (red) to the positive battery terminal (labeled with a "+" on the battery) of the dead vehicle. Be sure the connection is strong with the clamp securely "biting" onto the battery terminal.
Step Three
Connect the other end of the positive cable (red) to the positive battery terminal on the booster vehicle (again, confirm that a "+" is next to the battery terminal). If the terminals are corroded on either vehicle, you may have to scrape them with an abrasive such as steel wool to achieve a solid connection.
Step Four
Connect the negative cable end (black) to the negative battery terminal on the booster car (marked with a "-"). Finally, attach the other end of the negative cable to an unpainted metal surface on the engine of the dead car. Find an unpainted bolt or bracket that is as far from the dead battery as possible. This will provide a solid ground while further reducing the possibility of igniting any hydrogen gas.
Step Five
Make a final check to confirm that the jumper cables are not near any moving engine parts, and start the booster car. Let it idle for several minutes, depending on the state of the dead battery. If the dead battery is new and was drained by the lights being left on an extended period of time, it will probably start immediately. If it is an old battery or it has sat for a long time (more than a month) it will probably take awhile to charge it sufficently.
Step Six
Start the dead vehicle and let the two vehicles idle for a few minutes. If the dead vehicle refuses to start, don't keep trying or you might damage the starter. If there is the possibility of additional problems, like a lack of fuel, don't continue trying to start the dead vehicle until the other problem(s) are solved.
Step Seven
Once the dead vehicle is started and running smoothly, disconnect the jumper cables in the reverse order that they were connected. As you disconnect them, be careful not to let the dangling cables fall into the engine compartments or touch each other.
https://www.google.com/search?q=conn...utf-8&oe=utf-8
Step Two
Step Three
Step Four
Step Five
Step Six
Step Seven
plus 1. for example, i hate it when customer bring in their car to the dealership and ask me to program something on their car. my answer to the dumbass service advisor is "hey f-tard, not my car read the owners manual"
