Homelink Programming Without Garage Door Opener Remote?? Smart Learn Button
Old Dec 23, 2014 | 08:08 PM
tite_tite's Avatar
tite_tite
I lost my garage door opener remote & having no luck in programming my homelink via the "Smart" "Learn" button.
I clear the memory.
I tried pressing the button on the mirror 2 secs for 3 times after hitting the learn button as the manual stated. "press/hold/release" but no luck.
I tried pressing the button on the mirror & holding it for 90 secs and/or more after hitting the learn button but no luck.
2010 G37: craftsman garage door opener (5/98)
Thanks in advance
Old Dec 24, 2014 | 05:01 PM
13_SkylineSedan's Avatar
13_SkylineSedan
I believe you need to have one working remote to "teach" the Homelink unit what kind of signal to emulate, so you'll probably need to buy one. They're not very expensive but obviously it needs to be compatible with your opener / brand and model number. Then go through the steps, use the remote to teach the Homelink, then teach the opener to listen for the Homelink...
Old Dec 24, 2014 | 06:20 PM
WillCo1's Avatar
WillCo1
You need the device to send the signal to the Homelink.
Doesn't just somehow pickup the signal of the garage door opener.
Old Dec 25, 2014 | 12:40 AM
tite_tite's Avatar
tite_tite
thanks for the input..
upon further researching, it appears the "smart" "learn" is to program the garage remote control.
in summary: in order to program the homelink, a garage remote control is required.
thanks a bunch g37 members
Old Dec 25, 2014 | 12:48 AM
speedracer g37's Avatar
speedracer g37
go on amazon. craftsman garage doors are made by liftmaster and remotes are pretty cheap to buy.
Old Dec 26, 2014 | 12:24 AM
tite_tite's Avatar
tite_tite
do you know if one of those remote control key look alike will work? see attachment for pictures.
i read that those key remote doesn't work.
Attached Thumbnails Homelink Programming Without Garage Door Opener Remote??  Smart Learn Button-garage-remote.jpg
Old Dec 26, 2014 | 04:38 PM
HoldmyMouse's Avatar
HoldmyMouse
Just make sure the frequency is compatible.
Old Jan 2, 2015 | 01:42 PM
JT2014's Avatar
JT2014
I didn't need one to program my door? The unit had a learn button for programming on the back of it. I had to push that & then run to the car within 2 minutes & program the homelink. It treats the homelink as a remote.
Old Jan 3, 2015 | 11:50 AM
13_SkylineSedan
Perhaps somebody had already trained the transmitter in your car and it happened to be compatible with your opener (?) because you skipped the first 3 steps
Attached Thumbnails Homelink Programming Without Garage Door Opener Remote??  Smart Learn Button-homelink.jpg
Old Jan 8, 2015 | 12:11 PM
SwissCheeseHead's Avatar
SwissCheeseHead
Just want to clarify that you DO NOT need a remote to program homelink. You can use the "learn" button that's located on the door opener itself. Most people fail to follow the "rolling codes" procedure that can be found on various Youtube videos. Most Craftsman door openers, (rebranded Chamberland/Liftmaster) have rolling codes.
peterso2
Mar 25, 2019 11:28 AM
OneSickBlackG
Jan 6, 2016 08:49 AM
Raleclair
Oct 8, 2015 02:06 PM
xnick101
Intake and Exhaust
18
Sep 16, 2015 12:02 AM
