Has anyone been refused warranty service over owner installed accessories?
Old Feb 18, 2014 | 12:08 PM
SilentR's Avatar
SilentR
I think I have a problem with my BCM - I've had all the windows go down on their own a couple of times, and the door lock horn beep no longer works, which is kind of a blessing. I've installed DRL's and a trailer wiring setup, both have inline fused power leads that attach to the battery terminals. The trailer wiring has a module that runs the separate brake and turn signals, and has a connector that plugs into the factory harness next to the drivers side tail light. (No cutting)
I've read about service departments refusing to work on cars that had aftermarket alarms installed, which is reasonable because any I've seen had a LOT of splices. Probably applies to remote starters too. In my case, both were simple plug ins, and have been working fine for a few months, the BCM thing is recent. I've also pulled both fuses with no change.
I know each service department is different, but has anyone experienced warranty refusals because of non factory accessories? I suppose I could pull everything out, but the heavy 12GA power wire for the trailer module runs right by the BCM in the passenger footwell where the tech would see it. It was a serious pain to get it in and through the rubber cap on the windshield cowl, I really don't want to do that again.
Lt8Che
91
Apr 8, 2022 04:55 PM
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
BANNISTER
Dec 10, 2015 04:14 PM
drewfinity
Aug 20, 2015 08:17 PM
