Cel p0447
Old Feb 13, 2014 | 01:13 PM
xtremeroller's Avatar
xtremeroller
Cel p0447
My car just threw code P0447 yesterday. I have tried removing and replacing the gas cap on tight and the code still comes back. Has anyone had any experience with this issue and if so, how did you fix it? Thanks for any help you guys can give me.
Old Feb 13, 2014 | 09:53 PM
xtremeroller
So, no one has had this problem?
Old Feb 16, 2014 | 01:15 AM
xtremeroller
Anyone?????
Old Jun 21, 2019 | 05:23 PM
GodlikeRage's Avatar
GodlikeRage
Did you ever fix the problem?
Old Jun 27, 2019 | 11:46 AM
Surfnazi's Avatar
Surfnazi
Vent tube that your gas tank uses to vent gas flow is known for going bad
Old Jun 28, 2019 | 06:14 PM
BeeW's Avatar
BeeW
And theres a TSB and extended warranty that Infiniti will only honor after you've forked over $350 for a diagnosis and inspection. Better be real broke before you take it in.
Old Jun 28, 2019 | 10:40 PM
GodlikeRage
That's crazy, the part is only like $60 on amazon.. At least the Purge Valve is.
Old Jun 29, 2019 | 01:58 PM
Baadnewsburr's Avatar
Baadnewsburr
vent valve=/= purge valve...good news is you can get a lower mileage charcoal canister with a vent valve on it on ebay for about 50-60 dollars
Old Jun 30, 2019 | 07:59 AM
GodlikeRage
I’ll just change the valve. not sure how to even take out the whole canister
Old Jul 1, 2019 | 10:27 AM
Baadnewsburr
its just a few screws, the pressure sensor connector, and a couple hose clips..(about half of wthe stuff you'd be disconnecting anyways just to change the valve), but either way if the problem is solved its solved doesn't really matter which way you do it, good luck
Old Jul 1, 2019 | 11:05 AM
GodlikeRage
Still not coming out. where exactly are these screws?
Old Jul 1, 2019 | 12:36 PM
Surfnazi's Avatar
Surfnazi
Did you undo connection to tank and I think there is a bottom clip as well
Old Jul 1, 2019 | 12:38 PM
Surfnazi's Avatar
Surfnazi
If you are in warranty or just a little over they should cover. I had some out of warranty work similar and my dealer did repairs under goodwill
Old Jul 1, 2019 | 12:55 PM
GodlikeRage
nope it’s a 2009
Old Jul 2, 2019 | 12:24 PM
Surfnazi's Avatar
Surfnazi
Just replace it it's not expensive
ill12will8
Oct 26, 2015 10:09 PM
eksigned
23
Aug 13, 2011 10:57 AM
snaik69
General Tech Questions
Feb 25, 2010 10:33 AM
Graham
Sep 15, 2009 07:43 PM
Lucky_One
Intake and Exhaust
Feb 17, 2009 03:21 PM
