Which brand of OIL FILTER do u use?
Old Jan 7, 2014 | 11:39 AM
canucklehead's Avatar
canucklehead
i use Wix in the larger size (for the M56). i see no value (for me) in spending more on the fancy "performance" filters. Wix make very high quality filters (no cardboard) and are the suppliers for many other labels. i also use Wix for cabin and air filters. great product, great price point.
Old Jan 7, 2014 | 11:52 AM
rlo's Avatar
rlo
I use any high quality filter that is on sale. K&N, Mobil 1, Purolator Pure one, or Bosch in the black can. I stay away from the rest.
Old Jan 7, 2014 | 02:19 PM
JMS2000's Avatar
JMS2000
Purolator PureONE w/ Pennzoil Platinum 5w30 here.
I saw a thread a while back where someone dismantled and compared various brands of filters (including the OEM filter). I'll try to dig up the link.
Old Jan 7, 2014 | 02:24 PM
NJ Torque's Avatar
NJ Torque
Factory nissan filters.
Old Jan 7, 2014 | 02:30 PM
JMS2000's Avatar
JMS2000
Ahh... weak... I think this was the thread, but all the pictures/links are broken.
https://www.myg37.com/forums/engine-...otsa-pics.html
Old Jan 7, 2014 | 03:15 PM
Adam West's Avatar
Adam West
I've been faithful to the Purolator PL14610 PureONE Oil Filter. You can even get them on Amazon now for a good price. Typical OCIs with Pennzoil Ultra ~7500 miles with these filters.
Old Jan 7, 2014 | 04:33 PM
stever07's Avatar
stever07
Purolator Pure One in M37 size.
Great article here: oil filters revealed
Old Jan 7, 2014 | 04:41 PM
pricojorge's Avatar
pricojorge
nissan oem
Old Jan 7, 2014 | 04:48 PM
pricojorge's Avatar
pricojorge
I use Bosch Premium filters, and use the bigger M56 filter, much bigger than our puny G filters, my UOAs have been very good (also using Pennzoil Platinum)
I would stay away from the cheapest filters.
What is the benefit of having a bigger filter ? would it need a bit more oil as well ?
Old Jan 7, 2014 | 05:26 PM
rlo's Avatar
rlo
The benefit of a larger filter is a matter of debate yet many of us do it anyway. I think the majority of us here that use larger filters believe that more oil can be filtered through a larger filter and possibly better cooling of the oil. The OEM sized filter is also exceptionally small for a 6 cylinder engine compared to OEM filters of a 4 cylinder. The size difference is not that huge from what people have recommended here about 1/3 larger than stock G37 filter.
Does it require more oil yes, about .2-.4 qts more.
Old Jan 7, 2014 | 07:39 PM
A greater surface area of filtration will filter more effectively and won't be prone to flow restriction over long OCIs. It may not be much of a difference but like mentioned above, our OEM filter is very small for a higher output motor and anyting to maximize oil flow is a step in the right direction. I've always used the bigger filters available for almost all my vehicles and in 35 years have never had an oil related problem or oil consumption issue.
Knock on wood
Old Jan 7, 2014 | 08:04 PM
SlimTV's Avatar
SlimTV
To sum up whats been already said. If you're using regular oil, stick with any good brand oil filter like Amsoil, Bosch, Purolator, OEM, etc.. If you're going synthetic use a name brand, extended life filter like: Mobil-1, Fram Ultra Synthetic (with "XG" in the part#), K&N, Royal Purple, etc.. K&N has a 17mm nut on the filter to allow quick removal with a socket, and they all are engineered to go up to 15,000 miles with 99% or better filtration efficiency. Just be sure to order the larger QX56 filter. Good luck.
Old Jan 7, 2014 | 09:27 PM
Glover998's Avatar
Glover998
As i'm with stillen oil cooler, factory filter doesn't work anymore, So had to use bigger diameter filters ..
For a reference, these are some examples that work with Stillen oil cooler:
Purolator PureOne PL10193
Purolator PureOne L10193
Fram XG3950 ( plz don't use Fram PH3950 that comes with stillen oil cooler, better to use the XG instead ).
Fram TG3950.
Wix 51381.
Just loved to share and help those with Stillen oil coolers as i had a bad time searching for these, finding out what works with my Stillen's .
Old Jan 8, 2014 | 12:40 AM
  #29
DONTTASEMEBRO's Avatar
DONTTASEMEBRO
try them all see which one you like. I went from oem to k&n with PU then RP with RP oil, and I like k&n the best imo
Old Jan 8, 2014 | 11:55 AM
  #30
heftylefty58's Avatar
heftylefty58
What criteria do you use when rating how much you like various oils & oil filters? Just curious....
