Oil Filter choice..
Old Nov 24, 2013 | 02:10 PM
G37xS1's Avatar
G37xS1
Oil Filter choice..
Before I start writing anything else, I do want to say that I have extensively searched and read as many oil threads as I can and I know how it upsets everyone on this forum when a newbie asks a dumb question when its been answered numerous times in various threads. I'm hoping this won't fall into that category...
I recently got a 2013 G37xS Coupe (Graphite/Stone, Prem, Nav, Sport), and its approaching 2700 miles so I'm looking into changing the oil out. From all the threads there are about oil, I've chosen to stick with Pennzoil Ultra (if i can find it) or Platinum if I can't.
My question is about the filter. I have narrowed my choice to either K&N or Mob1 filter, but I can't stand how tiny it is. I read in various posts that people have used the M56 spec without any issues. Is there a significant/noticeable difference in quality or the way the car performs?
For the K&N application, the G37 takes the HP-1008 and the M56 takes the HP-1010. For Mobil1 EP, G37: M1-108, M56: M1-110.
Are there any negative reasons or any reasons at all NOT to use the larger filters?
Thanks in advance for everyone's input!
Old Nov 24, 2013 | 02:17 PM
BluestickG's Avatar
BluestickG
I have used KN, Mobil and Nissan factory filters. There is no difference that I can tell besides that of the price.
Old Nov 24, 2013 | 02:26 PM
If it fits, it's fine. You can use almost any filter that is designed to fit a Nissan model.
Old Nov 24, 2013 | 06:09 PM
I use Bosch Premium filter but I use the bigger M56 filter, it's about a third larger than the puny G filters.
Old Nov 26, 2013 | 01:13 PM
TIM IN NC's Avatar
TIM IN NC
I use amsoil oil and either the amsoil oil filter or the wix. it is a minor hassle to change the oil due to the shroud. Since I don't put a lot of miles on the G, I change the oil once a year. Included the specs from the amsoil page for the tech obsessed.
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......SM
Maximum Performance SAE 5W-30 Signature Series 100% Synthetic Motor Oil (ASLQT)
Performance Plus XL 5W-30 Synthetic Motor Oil (XLFQT)
Performance OE 5W30 Synthetic Motor Oil (OEFQT) All TEMPS......5W-30 [1]
Manual Transmission,FS6R31A (6-SPD)......GL-4
All TEMPS......75W-90, 75W-85
Synthetic Manual Transmission and Transaxle Gear Lube (75W-90) API GL-4 (MTGQT)
Automatic Transmission,RE5R05A......SLF [2]
Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid (ATL) (ATLQT)
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
OE Fuel-Efficient Synthetic Automatic Transmission Fluid (OTLQT)
Differential, Front......GL-5
Above 90 F......90
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
SAE 80W-90 Synthetic Gear Lube (AGLQT)
Below 90 F......80W-90
Differential, Rear......GL-5
Above 90 F......90
[1] SAE 5W-30 is preferred.
[2] Use Geniune Nissan Matic S transmission fluid. If not
available Nissan Matic J can be used.
FILTERS:
Oil Filter Absolute Efficiency Oil Filter (EA15K12)
Oil Filter WIX 51365 Oil Filter
Air Filter WIX 49362 Air Filter [1]
Cabin Air Filter WIX 24479 Cabin Air Filter [2]
[1] Takes 2; Not all models may be outfitted with a cabin air filter. Please verify before ordering.
[2] Not all models may be outfitted with a cabin air filter. Please verify before ordering.
NGK PLUGS AND WIRESETS:
No Recommendations
WIPER BLADES:
Blade Class Driver Passenger
NeoForm T16260 T16170
Winter T37260 T37170
CHASSIS LUBRICATION:
0 Fittings, 0 Plugs
CAPACITIES:
Engine, with filter..........5.2 quarts [1]
Cooling System, Initial Fill..........9.5 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, RE5R05A Initial Fill..........Not Specified
Automatic Transmission, Total Fill
5 speed RE5R05A..........10.9 quarts
Manual Transmission, FS6R31A (6-SPD)..........5.9 pints
Differential, Front..........1.3 pints
Differential, Rear..........3 pints
[1] After refill check oil level.
TORQUES:
Oil Drain Plug.....25 ft/lbs
Manual Transmission
Fill Plug 25 ft/lbs
Drain Plug 25 ft/lbs
OTHER TOP QUALITY PRODUCTS:
Mothers® Car Care Appearance Products
By-Pass Oil Filters
PI Performance Improver Gasoline Additive
Product Recommendations and Drain Interval Chart
Old Nov 30, 2013 | 11:17 AM
unknowndesi's Avatar
unknowndesi
I second the AMSoil filter. It's designed to run 25,000miles but I change it every 3. The filter membrane filters out more ppm than most brands on the market. I've cut one open and compared it to a typical fram oil filter and I can assure you guys that there is a proper filter membrane inside made from synthetic materials and metal parts compared to fram and most competitors paper membrane. I trust their products and use them as much as I can
Old Nov 30, 2013 | 07:26 PM
inyquest's Avatar
inyquest
A larger oil filter?
So it fits?
Does a lager filter help?
Old Dec 1, 2013 | 02:39 AM
datboiroy's Avatar
datboiroy
I use purolator oil filters.
Old Dec 1, 2013 | 02:47 AM
bleu ardoise's Avatar
bleu ardoise
microGreen MG101-7
http://www.microgreenfilter.com/how-it-works
Old Dec 1, 2013 | 08:43 AM
warped ideas's Avatar
warped ideas
A quarter past stripped
I couldn't believe the size of the filter when I first changed the oil on my G. My Harley uses a larger filter. LOL I always use K&N in my vehicles. I've never had an issue with any of my vehicles. It's a little more pricey but not much more. I'm with whats been said before though. All the forementioned products are a good choice. I just think it's a preference thing.
Old Dec 1, 2013 | 12:47 PM
cv129's Avatar
cv129
OP, the K&N and M1 EP filter have the exact same internal construction. They are literally the same filter, made by the same manufacture. The only difference is K&N has that little nut on top so you can wrench it on/off.
Old Dec 1, 2013 | 03:03 PM
Racindaddy's Avatar
Racindaddy
Purolator Pure One PL14610. Same circumference as stock, but about twice the height. 99.9% efficiency. Available at any auto parts store. And economical.
Old Dec 1, 2013 | 06:07 PM
Rad_Slinger's Avatar
Rad_Slinger
So it fits?
if it's the same diameter and thread pitch/count, then yes, it will fit.
i also do as BL does, but with the K&N filter. the K&N filter for our Gs is the 1008 (i believe)....i use the 1010 in mine. it's a much larger (taller) filter. bumps the oil quantity from 5.25qts to just under 6qts...and obviously has a much larger filter element inside.
Old Dec 1, 2013 | 06:34 PM
Yep, any filter for the M56 will fit, and it WILL still fit under the plastic splash pan w/ a little room to spare
Old Dec 1, 2013 | 07:31 PM
huwee06's Avatar
huwee06
I use Red Line 5w-30 @ 7k mi OCI, M45 filters, Bosch D+ #D3323 or Purolator PureONE #PL14610 (work nearly as well), you can read up on some reviews/comparisons here: Some Filtration Comparisons from the Bench | Oil Filters | Bob Is The Oil Guy
-and-
Bosch Distance Plus D3323 and Particle Count | Oil Filters | Bob Is The Oil Guy
