Liquid additive
Old Feb 15, 2012 | 02:13 PM
TeeItHi's Avatar
TeeItHi
Liquid additive
Just wondering if anyone here use any liquid additive for your G?
- fluel
- cooling
- oil
For yourself to help loose weight during track days. hahaha
Old Feb 15, 2012 | 05:08 PM
I use Redline Water Wetter. I run a can of Seafoam through the fuel lines every year or so. I also use it in the upper cylinders and run it in the crank case about every 4th or 5th oil change.
Old Feb 15, 2012 | 06:39 PM
TVPostSound's Avatar
TVPostSound
Seafom, good stuff!!
As mine is no a DD, only a weekend warrior.
I need to run Startron here in Cali, as the gas is 10% ethanol.
You should see what it did to my boats fuel system.
Old Feb 15, 2012 | 06:43 PM
xtremeroller's Avatar
xtremeroller
Yes, seafoam is a great product. Going to add water wetter to mine when it's time for a coolant change.
Old Feb 15, 2012 | 08:02 PM
A_Palaroan's Avatar
A_Palaroan
i use whatever they have at the gas station lol. i do it every other fill up.
Old Feb 16, 2012 | 04:47 AM
ShyAznB8oi's Avatar
ShyAznB8oi
whats a good fuel cleaner **** to use?
i think I need to do it now lol or asap on a full tank of gas
Old Feb 16, 2012 | 07:48 AM
Coprolite's Avatar
Coprolite
Can't go wrong with Techron.
Old Feb 16, 2012 | 11:15 AM
TeeItHi's Avatar
TeeItHi
this is great. i'll use these this week.
one question. i was on seafoam website and it seems like the motor treatment is what you would use for both fuel treatment & upper cylinder or did i miss a product?
thanks
Old Feb 16, 2012 | 11:23 AM
SwissCheeseHead's Avatar
SwissCheeseHead
Is seafoam safe to use? It always makes me leery adding additives to any parts of my car. I've had bead experiences with Heet and other fuel system "cleaners".
Old Feb 16, 2012 | 11:31 AM
thanks
Nope, same stuff. One product can be used for fuel tank, upper cylinders, and crank case. Check Youtube for videos from Seafoam and directions on how to use it.
I believe it is. It is 100% petroleum based, no solvents at all. I've used it on multiple cars including my '96 Maxima with over 220K trouble free miles with no issues. I've used it in all 3 locatios above on my G at 30K miles or so and I'm at 76K now. No issues thus far. I'll use it again soon.
Old Feb 16, 2012 | 12:45 PM
t-bone1924's Avatar
t-bone1924
I started adding some RedLine SI-1 Fuel Injector System Cleaner to the gas thinking that maybe it will help the throttle body from getting dirty and causing irregular idling.
Anyone know if this would help? Or am I just wasting my money?
Old Feb 16, 2012 | 02:06 PM
Tazicon's Avatar
Tazicon
No additives except for what Shell puts in their fuel, never have never will.
Old Feb 16, 2012 | 06:34 PM
novaleadfoot's Avatar
novaleadfoot
todays gasoline has plenty of cleaners...engine oils are also engineered to clean and protect...oil additives do nothing positive and actually hinder the performance of the oil by foaming up, creating air bubbles, and increasing heat...bobistheoilguy has an article somewhere on this topic (that's where I am paraphrasing the info from)
Old Feb 16, 2012 | 07:17 PM
Coprolite's Avatar
Coprolite
The throttle body has to be manually cleaned, as it is upstream of the injectors. Isn't it?
Old Feb 16, 2012 | 07:18 PM
Coprolite's Avatar
Coprolite
To put it simply, if you use Top Tier gas, you'll be fine.
