Help High-pitched sound when going any speed over 5-10mph
Hello all,
I've done some searching online and in this forum, and the best I could find was someone who had a low woofery sound when going at higher speeds.
My problem is different, and highly irritating: whenever I accelerate to 5-10mph, I hear a very high-pitched distinguishable sound coming from somewhere to the right of the driver's seat... it hurts my ears sometimes.
I've gotten my brakes checked out for squealing multiple times and they've been deglazed (though they still squeal... that's another issue altogether). I'm not sure if it is brake related but I can't figure out what's causing it.
The sound stops whenever I slow down below 5-10mph, and turning at any degree doesn't seem to affect it.
Any idea what this could be? If it's brake related, and I want to completely replace them, an extended fully covered warranty should take care of that, right?
Thank you.
Thank you.
I had that also when I first had my G.. But mine was around the 15-20 mph.. It's like that cutting high ptich noise. I think it had to do with my axles back then and needed to get tightened or something. Let them know the sound on the test drive, they should figure ito ut.
could be this - https://www.myg37.com/forums/g37-sed...ncy-noise.html .. have fun trying to get it changed it if is.
sunshineskyler
Nov 13, 2015 09:47 AM
