Air bag light
Old Apr 9, 2011 | 07:00 PM
DIE FAST's Avatar
DIE FAST
Air bag light
i m rebuilting a 2010 G37 X coupe , the car is back from the frame master and the air bag light is flashing ! maybe cause i ve disconected the AB senssor behind the radiator ? every senssor are connected but still have my Air Bag light flashing ?? Need help !
Old Apr 9, 2011 | 08:17 PM
Replace the airbag.
Old Apr 10, 2011 | 08:41 PM
DIE FAST's Avatar
DIE FAST
are you sure ? the air bag was ok before the frame master , why should i replace it ?
Old Apr 10, 2011 | 09:04 PM
Modme's Avatar
Modme
You dont need to replace the air bag. When any airbag component is disconnected and the car is turned on, the SRS unit will log an error and trigger the light. You will need to reset the SRS unit.
To clear the code:
1. Turn ignition switch from off to on.
2. Air bag warning lamp is on for 7 seconds and turns off, then turn ignition switch off within 1 second after the lamp turns off.
3. After ignition switch is turned off, wait for more than 3 seconds.
4. Repeat steps 1 to 3 twice. (perform 3 times in total)
5. Turn ignition switch on. (Now in diagnosis mode)
6. Turn ignition off to clear codes.
Old Apr 10, 2011 | 10:25 PM
DIE FAST's Avatar
DIE FAST
it works perfectly !!!!! thanks a lot Modme !!!
Old Apr 11, 2011 | 12:56 AM
advan37's Avatar
advan37
Is your car equipped with Intelligent Cruise Control (ICC)?
Old Apr 11, 2011 | 08:10 PM
DIE FAST's Avatar
DIE FAST
Yes it is .
why ?
Old Oct 6, 2011 | 06:22 PM
RISKY GUY's Avatar
RISKY GUY
Cool
To clear the code:
Thank you for this post.
Just saved me a 2nd trip to the dealer.
Old Oct 6, 2011 | 08:21 PM
Modme's Avatar
Modme
You got it.
Old Oct 6, 2011 | 08:53 PM
Doggy's Avatar
Doggy
This should be stickied on how to reset airbag light
Old Oct 6, 2011 | 09:06 PM
RISKY GUY's Avatar
RISKY GUY
Modme, thanks again.
You diagnosed what the consult 3, couldnt even find.
Fail for the service writer.
Should be interesting when i cancel service appointment.
It should be also listed as "things the dealer has no clue how to fix"
Old Oct 6, 2011 | 09:14 PM
WPPJR30's Avatar
WPPJR30
Hmmm... I need to try this.
Old Oct 6, 2011 | 09:50 PM
tallbrownie's Avatar
tallbrownie
will it work for g37 09 sedan
Old Dec 29, 2013 | 03:26 PM
botlfed98's Avatar
botlfed98
thanks!!!!!!
Peepz
Sep 9, 2015 06:51 PM
luisalan
Sep 6, 2015 05:45 PM
Steezus_g37
Sep 5, 2015 04:41 PM
