Service Engine Soon Light
Old Mar 25, 2011 | 08:15 AM
liscmad's Avatar
liscmad
Just driving to work today and all of the sudden the service engine soon light appears. My car has 42.6K miles and it had an oil change at the dealer about a month ago.
I turned off the car when I arrived at work and restarted it with the same light appearing.
Any ideas what it might be?
Old Mar 25, 2011 | 09:06 AM
KLB's Avatar
KLB
Did you buy gas recently?
Old Mar 25, 2011 | 09:07 AM
liscmad's Avatar
liscmad
I have not recently purchased gas. I filled it up over a week ago.
Old Mar 25, 2011 | 09:25 AM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Could be a lot of different things. Unfortunately without really knowing exactly what happened to the car over the past couple days the only way to diagnose it is if you have an electronic code reader or take it to the dealer
Old Mar 25, 2011 | 11:09 AM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
^^^+1 have to pull the code
Old Mar 25, 2011 | 08:48 PM
eksigned's Avatar
eksigned
your local auto store will be able to pull the code for you. free of charge
Old Apr 19, 2011 | 09:28 PM
67charger's Avatar
67charger
how can you read the code without using a code reader?
thanks
Old Apr 20, 2011 | 02:53 AM
AZg37's Avatar
AZg37
^^^ you can't read the code without an OBDII reader. Most parts stores like checkers, auto zone etc.. will read the code for you and tell you what it is. If you post the code on here, I'll check it against the infiniti service manual and tell you whats wrong and what could be the cause, plus how to diagnose the fix. This way the stealership wont rip you off !
Old Apr 20, 2011 | 05:02 AM
eksigned's Avatar
eksigned
^ whoops. my fault. AZ got it...OBDII readers can be borrowed from your local auto store.
Old Apr 20, 2011 | 11:33 AM
CDONNS's Avatar
CDONNS
Doesn't the hidden diagnostic menu give you some error history? Or does it not show codes like this?
Old Apr 20, 2011 | 01:01 PM
AZg37's Avatar
AZg37
From my understanding, the hidden diagnostics menu pertains to all the a/v stuff in the car. It will show errors with the speakers, back up camera, ipod hookup, sat antenna, nav unit etc.. as well as run self diagnosis to make sure your a/v components are functioning properly. It will not display CEL's (check engine light) or the codes associated with them.
Old Apr 20, 2011 | 02:35 PM
CDONNS's Avatar
CDONNS
Alright cool. I figured that was all, but thought I'd throw it out there
Old Apr 20, 2011 | 03:30 PM
Fezzik's Avatar
Fezzik
There IS a way to get codes without a OBDII You just have to know what the codes mean. I've gotten all my codes this way from aall my nissans and infinitis
The check engine light will flash in a style like sos and give you the codes once you enter diagnostic mode. for example (just random number) 0375 would be 10 flashes. then a pause then 3 flashes then a pause then 7 flashes, pause then 5 pause then repeat.
https://www.myg37.com/forums/d-i-y-i...isconnect.html
After step 3 when the check engine light blinks that is when you get the code. get the code and finish the rest of the reset ecu or turn the ignition off.
Old Apr 20, 2011 | 03:42 PM
AZg37's Avatar
AZg37
^^^^ or you can go to AutoZone and in 5 min they will tell you, code PXXXX, drivers side O2 sensor, and they can clear it to see if it will return
Old Apr 20, 2011 | 04:11 PM
Fezzik's Avatar
Fezzik
The link i provided also shows how to reset the ecu to clear codes. just 2 more steps after you read the code. Also Autozone corp has sent out memos saying that they are not allowed to clear codes. Some places will still clear codes.
