2010 G37x Strange Shut Down Noise
I now can reproduce the noise 100% of the time after engine is shutdown. And begin to hear it intermittently while the engine is on. It is hard to hear it while the engine is on due to the normal engine noise, but the noise is really there.
Hmm... I agree that the noise sounds like external rotation slowing down. Not anything internal. Whether that is fans, or pulleys I don't know. My best guess would be a bearing in a pulley thats starting to go bad.
As to your location... I wouldn't think that'd be the spot. Only thing inside that area is a "Butterfly". I'm wondering if the sound is perceiving to be that location.
Lastly, if its continuing to get worse and more pronounced, leaning more towards the bearing idea..
I dropped off my car in the dealer today and expected them to fix the noise problem. They called me back in the evening and said they cannot duplicate it!
I didn't believe them. So I rushed back to the dealer to show them. NO NOISE!!! Tried to start and shutdown several more times, still no noise.
After I arrived home and pull into my garage, I HEAR THE SQUEAKING NOISE AGAIN!!!
...you should play them your video.
I was able to reproduce and showed the problem to my mechanic friend. He said the noise is from the throttle body. This confirms the spot I circled on the photo.
Hmmm...
I would have thought the noise was coming from the radiator fan slowing down .. but I believe you if you heard it loudest at the area circled...
I wonder why it only occurs for me in the cold -- i would think something in that area would be very warm and less likely to make the noise?
The dealer confirmed the noise is from the throttle body. They say it's normal for 2010 G and to proof it, they showed me one of their loaner car with the same noise after shutdown.
Did the dealer explain to you exactly what is occurring in the throttle body that is causing the noise and why it is not consistent each time you shut down? I would expect a valid explanation for something that intermittently makes noise after engine shut down. It's probably good to keep this documented in the event you and possibly others experience premature throttle body failure.
The throttle bodies DO make a noise, but that noise is specific and sounds nothing like in the video. The noise the TB's make is similar to a buzzing sound, which lasts for 1 second maybe 2 after shut down. The noise in the video is like something is rotating, and sounds very much like a bad bearing, probably in one of the fans (Since the belt came to a complete stop before the sound stopped).
I originally believed the sound was from only the passenger TB...but the tech showed me it was from both TB.
They put a comment in the invoice about the noise and called it normal. So I have it documented just in case something really bad happen in the future.
#30
It's funny my car makes the exact same sound on shutdown. I already took it to the dealership for it and they also said it was normal. But I've been in other G37's from 09-12 and they didn't have the problem.
I know you said you thought it was the throttle body, I really think mine is the fan motor. The sound is much louder at the fan motor than anywhere else. Are you all sure it's the throttle body and not a possible batch of defective fan motors?
Thanks!
Thanks!
