Switching back and forth between oils?
Old Nov 8, 2010 | 12:37 AM
DoubleD's Avatar
DoubleD
Hey so I switched over and started using synthetic oil (mobil 1) after 10,000 km, I think the inifiniti dealer might have just mistakenly put conventional oil in my car yesterday... My mind might just be playing tricks because i've heard switching back and forth isn't good, but something feels just slightly off when im driving right now. Am I likely imaging things, is switching back and forth between types of oil bad for my engine? What should I do?
Thanks!
Old Nov 8, 2010 | 07:48 AM
KLB's Avatar
KLB
You'll be fine. Next time switch it to what you want. Don't go beyond the Schedule 1 mileage though.
Old Nov 8, 2010 | 09:42 AM
Blackjack's Avatar
Blackjack
One time isn't going to harm you, but I do believe being consistent with oil in your car does have benefits.
As KLB said, if you believe they put conventional in, be sure to change it after 3750 and resume using synthetic.
Old Nov 9, 2010 | 03:55 PM
SM_Shadowman's Avatar
SM_Shadowman
You might have heard that, but it's just a myth that never seems to die. You can switch between brands of oil, or from synthetic to conventional at every oil change if you wish.
Old Nov 10, 2010 | 10:40 PM
Ruvik's Avatar
Ruvik
Well every time i change oils conventional to synthetic I do an 5min engine flush that way most of the old oil will drip out. synthetic is a different blend of oil and sometimes foams when mixed with non-synthetic, and that is not good for your engine. So spend the extra 4 bucks and give your engine something to tickle about.
Lt8Che
91
Apr 8, 2022 04:55 PM
m3clubracer
Sep 13, 2015 09:01 AM
SS2006
Aug 11, 2015 10:24 PM
