Help A/C on all the time with Auto setting...
Old Feb 2, 2010 | 09:26 PM
xeon450's Avatar
xeon450
I've noticed through out the winter months here in Toronto that the A/C light is on all the time when the climate control system is set to Auto. I can manually switch A/C off, but it comes back on once I press Auto again.
I mentioned this to my Infiniti dealer, and he said that this is normal as the climate control system is sensing the humidity during the winter.
Is this normal/true?
Old Feb 2, 2010 | 10:22 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Yes, it is true that it always comes on when you turn the Auto Climate Control on.
No, I do not believe it is true that the reason it happens is b/c of humidity.
It turns on every single time you turn the Auto climate control on, regardless of the weather outside.
Old Feb 7, 2010 | 05:01 PM
Hitdog540's Avatar
Hitdog540
A/c
If you leave it on auto, the next time you start the car, the a/c will not come on.DOMO
Old Feb 7, 2010 | 10:14 PM
xeon450's Avatar
xeon450
That hasn't happened - A/C is on ALL the time in the AUTO setting, even after starting the car the next day.
Old Feb 7, 2010 | 11:55 PM
gsm026's Avatar
gsm026
This is typical with all cars I have owned with automatic climate control. They use heat and A/C together to balance the temp, and the A/C helps control humidity.
My Acura TL was exactly the same with one exception. On the Acura you could turn it to recirculate (say, if you were passing a dairy farm or dead skunk) without turning on the A/C. The control logic on the G37 turns on the A/C whenever you push the recirculate button. The A/C does not go off again when you turn recirculate off, you have to hit the button.
The G37 system does work automatically even after you turn off the A/C. As long as it is cool enough that it can keep the temp setting using outside air.
Greg
Old Feb 8, 2010 | 08:34 AM
Hitdog540's Avatar
Hitdog540
Last time
Just started the car...auto was already selected from yesterday with the A/C turned off yesterday. The A/C DID NOT come on. I repeat, the A/C did not come on. Not sure why you have a problem. It DOES come on when I first select auto but as long as I shut off the ac, and leave it in auto, ac does not come on. Try it!
Good luck
the dreame
Apr 9, 2017 10:30 AM
redlinernyc
Feb 29, 2016 11:06 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
Sway_NV
Sep 10, 2015 01:51 AM
thedonjp
General Tech Questions
Aug 14, 2015 11:14 PM
