What did I do wrong?
Old Apr 11, 2009 | 04:56 PM
yakuzapop's Avatar
yakuzapop
Last night, I was working on my Navi and Dvd....
now Air bag light is constantly flashing........and CD, Radio, Center infiniti clock don't work.....but climate control works.
I'm gonna replug harnesses tonight....Hope it works ok.......
Is there anyone had this problems?
grrrrr..........
Old Apr 11, 2009 | 04:59 PM
elite's Avatar
elite
What exactly were you doing?
Sounds like a blown fuse
Old Apr 11, 2009 | 05:07 PM
yakuzapop's Avatar
yakuzapop
did not touch any fuses.....I was just bypassing navi and screen.
Old Apr 11, 2009 | 05:44 PM
PureNick's Avatar
PureNick
There are two plugs that use the exact same harness so the fitting is the same. I think you criss-crossed the plugs which explains why your lights and center console is going nuts or just not working.
You may need to do an ECU reset to clear some lights. Be sure to make sure EVERYTHING is plugged back in before powering anything on... if you leave plugs out of their place just to "test" if things work, your cluster will light up like a Christmas tree and you'll have to perform a ton of resets to clear them all (or a trip to the dealer).
Old Apr 11, 2009 | 06:04 PM
yakuzapop's Avatar
yakuzapop
oh...I think maybe I corssed plugs......
I only have air bag warning lights flashing........
Thanks for info.....
Old Apr 11, 2009 | 06:06 PM
heff's Avatar
heff
now just ur air bag is flashing? if u un crossed the fuses you may have a problem with ur passenger seat, mine did this too but there was a recall on it just FYI, i dont know if thats the problem with urs but good luck brew
Old Apr 11, 2009 | 06:41 PM
jnguyen's Avatar
jnguyen
same thing happen to me, when you unplug your center console and everything. the Airbag is reset so what you have to do is reset your airbag then it should go away.
Old Apr 11, 2009 | 08:13 PM
yakuzapop's Avatar
yakuzapop
how can I reset my airbag??
Old Apr 11, 2009 | 11:18 PM
yakuzapop's Avatar
yakuzapop
anyone knows how can i resetting air bags?
Old Apr 12, 2009 | 05:56 PM
yakuzapop's Avatar
yakuzapop
New update:
I tried replug all harnesses that I moved around....
Audio/radio - fixed its working fine now
flashing airbag lights - still flashing constantly.
Center clock - still not working stopped at 12:30
Button on Door handle- its working but no beep sound
Old Apr 13, 2009 | 12:32 AM
Dieseldoug22's Avatar
Dieseldoug22
What happened was you probably turned on the ignition with the air bag "On-Off" light in the dash disconnected. You know to check if it works. That trips the air bag light. Google search for reset Infiniti air bag light. Some quick instructions and you will be working again. This same thing happened to me when I did mine.
Old Apr 13, 2009 | 02:40 PM
yakuzapop's Avatar
yakuzapop
Update:
Audio/radio - FIXED
flashing airbag lights - still flashing constantly. FIXED
Diode Dynamics
Lighting/Cleaning Products
81
Nov 30, 2021 02:28 PM
Rayramg37
Nov 18, 2015 09:06 AM
si_driver
ECU Tuning / Dyno Data
24
Sep 29, 2015 11:38 AM
deod
Southern California
Sep 15, 2015 08:12 PM
