Engine noise (from bank 2 VVEL actuator?)
i hope so too G37nS2K because all you do is whine about your G37 and stroke your S2K at every post oppurtunity you get. i don't know who is hurting more...you owning a G37 or me having to read why you think the G37 sucks and how the S2K is the second comming of Jesus Christ...LOL
More info'.........Revenge of the Nerd - Nissan in the sump with diamonds?
Long Term Update
Hi Guys,
Haven't been here in a while so I wanted to give you all an update on this issue. After further research it appears TSB ITB07-048 was *my* problem. This is well documented and the "fix" is to reprogram the ECM.
Dealer executed the TSB and problem disappeared for about 1 year. Problem came back this past August so I had dealer re-execute this TSB again. Problem seems to be gone again. I don't know if there is a permanent fix for this issue. I'm glad my lease on this vehicle is up in 3 months as I would not want to keep dealing with this dangerous problem anymore than I have to.
Best of luck to you all.
My 08 G37s(50k miles) has same issue. I just dropped it off at dealer this morning for the ECM reprogram, but seems the issue wasn't solved afterwards. Dealer gave me a lonar and told me will check again and call me back. Hopefully everthing is covered! Any of you guys fixed yours yet?
Tuckermaclain
10-05-2015 11:41 PM
Slapshot1
09-27-2015 08:40 AM
dedmanchan
09-24-2015 11:25 PM
