Help Floor Jack Points
Old Nov 16, 2008 | 12:09 AM
Skyline-LEXY's Avatar
Skyline-LEXY
Floor Jack Points
Where are these points located? Sorry Im noob with these stuff
Old Nov 16, 2008 | 12:13 AM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Someone should make a quick picture of this for the forums benefit... Im sure this question has crossed members minds at least once during the first year of ownership....
bump for a great question and idea....
Old Nov 16, 2008 | 12:14 AM
shumby's Avatar
shumby
If I had a car I would do it
Old Nov 16, 2008 | 12:51 AM
Skyline-LEXY
Thanks MAX
Old Nov 16, 2008 | 01:20 AM
IvoryG's Avatar
IvoryG
I haven't dropped my car yet so it might change. But I put a rag over my jack and jacked where the lower front control arm meets the front rear crossmember. Go in right behind the front wheels.
Old Nov 16, 2008 | 01:30 AM
Skyline-LEXY
^^ can you post a pic? It had to draw that in my head..
Old Nov 16, 2008 | 09:25 AM
AndrewDDS's Avatar
AndrewDDS
If you get out the jack in the trunk, there's a great diagram on the side of it. About a foot behind the front wheels, and about a foot in front of the rear wheels, there are two small notches in the car's frame. The jack point is directly between these two notches. If you look under the car and run your hand along the frame rail, you'll feel the little notches. Hope this helps!
Old Nov 16, 2008 | 09:57 AM
w0ady's Avatar
w0ady
^good info! ya the g35s were notched as well to tell you where.
Old Nov 16, 2008 | 07:23 PM
bfranks's Avatar
bfranks
Check this out. Very useful if you are trying to use a floor jack.
Old Nov 16, 2008 | 11:08 PM
PSYH's Avatar
PSYH
Post Whore
Your answer is right here with pictures and instructions.
fuzzed
Aug 21, 2020 09:35 AM
linvbro
Aug 22, 2016 01:25 PM
Irishcurtis
Sep 30, 2015 11:39 AM
r0cketm0nkey
Sep 27, 2015 01:34 PM
