compact flash
Old Oct 4, 2008 | 12:45 AM
edgar702's Avatar
edgar702
compact flash
Hi guys, just bought a new IP with black g37s 6speed, I love the car but have a few questions
first, I bought the scandisk 4gb card, I made 9 folders with mp3 in each and when I put the card in the car it will only open 7 folders and the rest is not showing but when I put it back in the pc it shows all 9, what em I doing wrong or has anyone experienced the same.
second, all my previous infiniti's had a feature when u turn the car off the seat and the wheel move so that you could get in or out easy, those this car have that, I cant find it
third. when the car is in neutral their is this loud clutch noise is this normal, and when the clutch pedal is pressed it goes away
thanks in advance
Old Oct 4, 2008 | 02:04 AM
bboysteele's Avatar
bboysteele
The CF card slot is limited to 512 mp3s. How many mp3s do you have in each folder? If you have more than 512 files total then it will not read. I don't believe there is a folder limit but there might be. My guess is you put close to a hundred mp3s in each folder so it only reads the first 7 folders which equals close to 512 files.
This G coupe does not have this feature. If you want you can set the second memory seat button to do this for you. This is a way around this if you want to use it.
This is also normal. Do a search and you will see a lot of people b!tchen about this but it is normal
thanks in advance
Answers in bold
Old Oct 4, 2008 | 03:48 AM
edgar702's Avatar
edgar702
thanks alot
Old Oct 4, 2008 | 01:40 PM
ghotnit's Avatar
ghotnit
I thought the CF reader was limited to 2GB cards. Am I mistaken? I have been only buying 2GB cards because of this.
Old Oct 4, 2008 | 03:21 PM
bboysteele's Avatar
bboysteele
You're mistaken. The CF card slot is limited on the number of files it will read. Most people only get a 2GB CF card due to it being big enough for 512 songs to fit on. Getting a bigger card is a waste of money if you are using it for this reason only. They is a guy on here though that bought 8GB cards to fit his songs on due to his songs being 8 to 20 minutes long because of them being techno tracks.
eljoker
Future Models
19
May 30, 2022 11:48 AM
Diode Dynamics
Lighting/Cleaning Products
81
Nov 30, 2021 02:28 PM
timc00k
Feb 15, 2017 09:15 AM
