Battery Size 35 vs 24F 2010+ Sedan
Old Feb 13, 2026 | 10:38 AM
AMP_01's Avatar
AMP_01
They do. You either have to perform a generic search or just use the "finder tool" using the M37 as the target vehicle. That's what I do (for a lot of things, lol).
I can't find 24f on their website battery search. M37 Nd even my R51 Pathfinder only pull up Group 35
Old Feb 13, 2026 | 11:09 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Here you go: Interstate Battery M37
I am leaning toward the MTX-24F... or just stick with the Red Top... Whichever/ whoever has it the cheapest. Eh, tomato/ tomahtoe...
Old Feb 13, 2026 | 12:20 PM
socketz67's Avatar
socketz67
Community Builder
If memory serves there might be a setting that can change that behaviour. I would have to do some checking as I am not 100% certain (plus I do not use that feature anyway). Either way, you would need CONSULT-3 to access those settings.
@socketz67
Edited to add: Apparently the only variable that can be changed for the "Auto Lamp" system is the timer delay setting for after the doors are closed (45sec. 60sec. 180sec. etc.). Regardless, you would still need CONSULT-3 to change that variable.
Thanks. I’m aware of that setting and it’s set to the minimum, but the fact that the lights stay on if you park then don’t open then close the door makes me crazy as I’m often on a call while driving, pull into the garage while on a call, then turn the car off.
I’m more disciplined now at moving the switch off then back to auto, so I’m managing.
Old Feb 13, 2026 | 12:54 PM
2010sedanS's Avatar
2010sedanS
Originally Posted by AMP_01
Does the battery cover clip back into place with that battery?
Yes, everthing fits perfect. The tie down as well.
Old Feb 14, 2026 | 05:13 AM
x818ray's Avatar
x818ray
Originally Posted by x818ray
Do not buy Costco. I got about 8 months out of it and their warranty sucks. Its pro-rated from day one. Best deal I found is Exide SPRINTER MAX from home depot. $129 3yr free replacement. (plus my no tax code=WIN...for me) Reviews are good although the warranty process might take a few days (deal breaker for some)VS same day from other stores. Walmart used to be my go to. For $97 3yr free- 5yr pro-rated they lasted exactly 3yrs. Now they're 3yr free replacement for $149. Still, not bad.
Different thread, same answer from 2 weeks ago. If you really want an AGM, Walmart is the way to go. $189 4yr warranty.
Old Feb 14, 2026 | 11:19 AM
JZ39's Avatar
JZ39
20 Year Member
Unfortunately, I had an optima red top on my FX 50 and it went bad in under three years. Pretty disappointed and just went back to a regular old battery at half the cost.
Old Feb 15, 2026 | 12:49 PM
socketz67's Avatar
socketz67
Community Builder
The battery came with something to sit on in the battery tray?
yes. I’ve seen some folks online struggle with the height and I think it’s because they believe the little stand that’s included is part of the packaging and not an actual adapter.
Old Mar 3, 2026 | 08:57 AM
projectpanda13's Avatar
projectpanda13
I'm running an Interstate 24F in my 2010. direct drop in and fits perfectly.
Old Mar 3, 2026 | 11:36 AM
mummy2's Avatar
mummy2
The largest battery life extender I’ve found is training myself to turn the lights off, then back to auto when I park and remain in the car (for instance, on a call). Otherwise, they stay on till you open, then close the door. If someone has a hack to turn that feature off, I’m all ears.
It turns off the lights after 15 minutes. Same if you leave your interior lights on.
Jackwagon
Jan 24, 2024 07:58 PM
twshivley
General Tech Questions
Feb 27, 2019 03:03 PM
JakeG37
Feb 2, 2019 11:25 AM
Zakheav
Mar 14, 2018 06:29 PM
Rr1982
Jul 5, 2017 11:07 PM
