Trouble codes
Trouble codes
Hi guys, I’m currently trying to get my 2009 g37x back on the road. Had gallery gasket issues which caused the car to spin a bearing. Had the engine replaced but I did not put the cats back on because I wanted to do test pipes instead. Everything has been working fine but the other day I got a code for a cylinder3 misfire and a code for a very small evap leak. I saw one of my coolant hoses was loose so I replaced the clamp and replaced the coil on cylinder 3. Do you guys think the evaporator code could have something to do with the loose coolant hose? Also I checked the IM readiness after erasing codes and it was showing the misfire monitor as ok. Would this mean the misfire was resolved. Thank you guys in advance
Murkr
Jan 13, 2023 08:56 AM
