Power to Seat/Mirrors not working
Old Sep 20, 2025 | 09:22 PM
chrisf8's Avatar
chrisf8
Electric Seats not working neither are my powered mirrors in my 2012 g37x, replaced the fuse, no change still no power. Where should I look next?
Old Sep 21, 2025 | 02:04 AM
13_SkylineSedan's Avatar
13_SkylineSedan
It's kind of complicated. Here's a link to the FSM describing the "Automatic Drive Positioner" system:
https://www.nicoclub.com/service-man...2012%2FADP.pdf
(Below the viewing window on that page you can "Click here to download a copy" of the pdf)
As you'll see there are 2 black boxes involved with seat and mirror memory; a "Driver Seat Control Unit" and an "Automatic Drive Positioner Control Unit". The BCM also has a hand in it, presumably identifying which key is connected to which drive position. Be aware that in addition to fuse #10 there is also a circuit breaker somewhere in the power line. Not sure where that is located and if it can be reset but it would be nice if that was your problem. That book is not an easy read but it gives you all the info you'd need to check the system. Good luck.
Wide boi
Nov 14, 2021 01:14 PM
akoragan
Mar 10, 2021 03:49 PM
Джон
General Tech Questions
Jun 15, 2019 03:57 PM
FresaG37x
Jan 27, 2014 09:44 PM
G37SBS
May 6, 2011 01:33 PM
