about to go on my 3rd AC Compressor in 80k miles, wtf?
Old Jun 9, 2015 | 01:53 PM
bat6wc's Avatar
bat6wc
Question about to go on my 3rd AC Compressor in 80k miles, wtf?
Bought the car new in 2008. My AC compressor went bad and was replaced under warranty at 38k miles in 2011. 2 years later, I report AC issues again. Dealer looks at it and claims nothing is wrong. Today at 82k miles, I have no cold air again. Car is at the dealer where they tell me the compressor is bad again and needs to be replaced for $1400. How does this keep happening? Anyone experience this? Ive called Infiniti Consumer Affairs and opened a case. I have a feeling its an electrical issue rather than the actual part going bad.
anyone have any helpful info to share?
I am quite angry to say the least.
Old Jun 10, 2015 | 02:11 PM
bat6wc's Avatar
bat6wc
seems like I am the only one. Maybe I should play the lottery...
Old Jun 10, 2015 | 02:21 PM
qmantran's Avatar
qmantran
Was the compressor clutch not engaging? Did they say what exactly pointed to a bad compressor?
My guess is you might have metal particulates flowing in your ac system which over time killed your compressor.
Generally after you replace a compressor for failure a safeguard is to install a inline filter to capture metal particles.
And of course a complete ac flush and service
Old Jun 10, 2015 | 02:23 PM
bat6wc's Avatar
bat6wc
Clutch not engaging and leaks at the o-rings. Im pretty sure they did an AC flush and service after the 2nd compressor install.
Old Jun 10, 2015 | 02:51 PM
RickyDgmZ's Avatar
RickyDgmZ
How often do you use your AC?
Old Jun 10, 2015 | 02:52 PM
bat6wc's Avatar
bat6wc
haha, I assure you, no more than anyone else. Summers in St. Louis get in the 90's and 100s easily. Aside from 3 maybe 4 months, the rest of the time is windows down.
Old Jun 11, 2015 | 01:04 AM
RickyDgmZ's Avatar
RickyDgmZ
Just asking because not using the A/C itself can cause the seals to go bad since they aren't being put to use. I'd say not using the A/C on the vehicle could be the most damaging thing allowing the freon to leak out and causing the compressor to run dry.
Old Jun 11, 2015 | 12:29 PM
paulmnly's Avatar
paulmnly
I live in Phoenix, AZ... I'm sure anyone familiar with the SouthWest KNOWS the struggle... We use our AC's on a daily basis... I haven't had any issues with it..... YET!
Old Jun 11, 2015 | 04:35 PM
tech37's Avatar
tech37
Yep! Not using the A/C is worse than using it everyday...also using the A/C help keep the evaporator coil free of damaging airborne contaminates...
In the owners manual of my 94 Legend...it actually says to run the A/C for a minimum of 10 mins per week...especially during the winter months to keep everything lubricated...
I never turn mine off...but I also live in the south east...
Old Jun 12, 2015 | 01:01 PM
bat6wc's Avatar
bat6wc
I find it hard to believe that not using my AC is causing this issue. 3 AC compressors!?!?!?! Come on. There has to be a fault, short or other issue causing this.
Old Jun 16, 2015 | 04:11 PM
bat6wc's Avatar
bat6wc
I filed a case with Infiniti/Nissan Consumer results. The result, they are willing to cover service costs if I cover the part. Ive found that the compressor and clutch can be had at around $640 new, so looks like Ill be buying the assembly. AC Compressor number 3!!!
Old Jun 16, 2015 | 05:50 PM
qmantran's Avatar
qmantran
$640 new? What a rip off. You must be buying from the dealer or somewhere similar.
I replaced a ac compressor in a 07 Honda accord with a oem Denso ac compressor w/ clutch for about $200 from amazon.
Honda websites and dealer was asking about $600.
I got the exact same brand Honda uses for $200 and did it myself.
Old Aug 14, 2015 | 02:10 AM
bat6wc's Avatar
bat6wc
well almost 2 months later and the AC is dead again. Im beyond pissed. Anyone know if I have legal action or if the lemon law applies?
Old Aug 14, 2015 | 03:38 AM
Jonesmeister11's Avatar
Jonesmeister11
Should be warranted for a year. Bommarito doing the work?
Old Aug 14, 2015 | 08:27 AM
telcoman's Avatar
telcoman
I don't think so.
If you paid by credit card to the dealer you might be able to get another replacement at no cost. Speak to the service manager.
If that fails request a charge-back from your credit card
As others have mentioned if you are not using your AC on a daily or frequent basis then perhaps it is you causing the problem.
I put 171796 miles on my previous 06 G35 6sp and used the AC daily even in 10 degree NJ winter weather and never had a AC problem.
Set the temp to whatever is comfortable for you and leave it alone
Just my $.02
Telcoman
