Code P0128 Question
Old Oct 7, 2024 | 04:55 PM
thunderG35's Avatar
thunderG35
Code P0128 Question
Hi,
Recently picked up a 2008 G35 sedan. After a few days, got a CEL. I only found code P0128.
I plan to replace:
1) coolant temp sensor;
2) thermostat;
3) air intake sensor; and
4) z1 coolant bleeder.
But, when I tested the heater, it blows freaking HOT and I don't know to replace the above if I don't have to.
Do you think that maybe that the coolant tank just needs a proper bleeding??? The seller told me he replaced the thermostat recently (if this is real or not, I can't confirm).
TIA
Old Oct 7, 2024 | 05:04 PM
thunderG35's Avatar
thunderG35
Hmmm, my car doesn't have a coolant bleeder ???
Is this a bleeder delete or something else here???
Old Oct 7, 2024 | 05:26 PM
beefychicken's Avatar
beefychicken
IIRC there isnt an OEM bleeder on the G35, definitely not one on the G37. You can get a coupler from Z1 that has a bleeder in it. Just loosen those two clamps and pull out the pastic piece and install the replacement from Z1, then bleed out the system.
And it looks a lot like there is leak at the coupler which could be causing your problem (leak is evident from all the staining around the plastic coupler)
Old Oct 7, 2024 | 06:34 PM
thunderG35's Avatar
thunderG35
I thought all G35s had the plastic bleeder that everyone talking about on the forums. Good to know.
I guess I'll start with the Z1 bleeder and do a proper bleed, then move on from there. Hopefully I don't get the bothersome CEL.
Thanks!
Infinibini
18
May 10, 2023 04:06 PM
rayycashh
Oct 11, 2022 03:42 PM
Davepel
Jun 18, 2021 08:04 PM
Kameronismyname
Nov 27, 2020 07:16 AM
latino914
Jul 10, 2020 02:44 PM
