2010 G37x Overheating when idle
Old Jul 16, 2024 | 08:18 AM
flashdex19's Avatar
flashdex19
I need help trying to figure out why car is overheating I don’t see no wet spots on the ground but my coolant reserve is overflowing I changed the radiator cap Al ready and I just put in a new radiator because I thought it was the radiator but it wasn’t also I just added a new thermostat. So do anybody have any ideas what’s causing my car to run hot when it’s idle at a red light the temperature rises 75 percent up dam near full but when I start back driving it’s goes back half way.
I even bleed the system twice to see if it’s air in the system
another thing my car is running lean on bank 1 and two because of a exhaust leak but I have new y-pipes coming so I don’t know if that’s the case I’m trying to see if it’s a failing water pump.
Old Jul 16, 2024 | 10:10 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Are BOTH of the fans turning ON?
This post will show you how to run the IPDM/er self-test. At full speed BOTH fans should be roaring loud moving air.
I had the exact same symptoms long ago. Everything was fine until I stopped at a long red light or a drive-thru (my bank the slowest on earth) the temp would start to spike but quickly cool down to normal once moving. Fans were shot (beach sand killed the bearings).
I'm 99% confident your water pump is fine.
Run the self-test and go from there.
Old Jul 16, 2024 | 11:01 AM
flashdex19's Avatar
flashdex19
thanks for the quick response I will give the test a try looks like I’m going have to replace the fans or relay.
Old Jul 16, 2024 | 06:14 PM
flashdex19's Avatar
flashdex19
I just got done doing the test I hear both fans running but I feeling like it’s not running as it’s supposed too idk you tell me.
Old Jul 16, 2024 | 11:57 PM
ILM-NC G37S
Well the fans are moving but it is hard to tell if they are running at full speed. It seems like they are but... I just can't tell.
Are you able to determine if the fans "ramp up" when going from 50% duty to 100% duty? You might have to run the test a few times to be certain. But they should run for 5aec. at 50% duty (medium) and then ramp up to 100% duty (full speed) for 5 more seconds at which time they should be roaring.
And you need to verify that BOTH fans are running at the same speeds.
Old Jul 18, 2024 | 02:26 AM
flashdex19's Avatar
flashdex19
both fan are running at the same time but I feel like they are not running full speed so idk what I should try next.
Charzardbolt
Jun 12, 2024 10:20 AM
ID10T
Apr 16, 2024 02:27 PM
asssets
14
Aug 1, 2023 12:34 AM
roro4848
Jun 26, 2023 03:27 PM
MAK789
14
Jun 7, 2020 02:51 PM
