OEM Headlight swap to Aftermarket
Old Feb 4, 2024 | 12:01 AM
BDE95's Avatar
BDE95
Hello.
I recently swapped out my OEM headlights on my Q40 to some aftermarket headlights. When swapping the hardware over, I noticed the ballast has an O-Ring for it. If I installed the ballast on the new headlight without this O-Ring, what sort of issues could I run into? If I need to take the headlight out and put in the O-Ring, that's fine, but was curious as to what purpose the O-Ring serves and what types of issues I could see without (assuming it protects the ballast/internal components from water damage?)
Thank you.
Old Feb 4, 2024 | 03:50 PM
Krzysztof47's Avatar
Krzysztof47
Water can get on the internals of the ballast and ruin it I believe.
The O-Ring is: 26033-CD010
Old Feb 4, 2024 | 03:52 PM
BDE95's Avatar
BDE95
Gotcha, thank you.I figured it would be an important piece for the ballast, so I'll get that O-Ring installed.
Old Feb 4, 2024 | 04:10 PM
Krzysztof47
No problem!
Earlblaize
Nov 12, 2013 02:35 AM
ijahman
Picture Share G Sedan
96
Feb 21, 2012 04:21 PM
AZg37
Apr 21, 2011 02:39 PM
iamgus_gus
Mar 29, 2010 09:18 AM
