Clunking noise
Old Nov 10, 2023 | 09:58 PM
Slateblueg10's Avatar
Slateblueg10
Clunking noise
New to the forums currently have a 2010 g37x sedan with BCs brs with an SPC camber kit been hearing a clunking I would say after accelerating from a stop and letting go after also can hear it while turning I am fairly low not maxed out I have done new end links lower control arm and wheel bearing recently (all unrelated except the end links) could it possibly be my swaybar ? Heard they don’t like being lowered but it was fine for awhile
Old Nov 15, 2023 | 10:49 PM
SkysG37's Avatar
SkysG37
Obviously double check your suspension components
also throw an eye on your diff bushing
Old Nov 16, 2023 | 07:53 PM
mummy2's Avatar
mummy2
Could it also be the infamous axle-clicking?
Old Nov 17, 2023 | 11:26 AM
Slateblueg10
don’t think it’s the axle clicking it’s a clunking noise I’ve checked all my boots recently before this noise came and fixed one but it’s only gotten worse
Old Nov 17, 2023 | 11:27 AM
Slateblueg10
I’ve double checked them and my diff bushing has been bad this is a front end noise clunking not rear end
also don’t see the diff bushing making noise from the front end when turning or hitting bumps
Old Nov 17, 2023 | 07:45 PM
beefychicken's Avatar
beefychicken
Might be a cracked sway bar.
Experienced a G35 that apparently had a "two piece" sway bar because it was cracked and split under the mount bushing.
We were troubleshooting a clunk noise and when we removed one of the sway bar bushings, the bar came out in two pieces. Found the source of the noise.
Old Nov 18, 2023 | 05:56 PM
Slateblueg10
I think this is a chance of bein my issue I thought it was end link related but noise persisted I have a hotchkis sway bar for the front I’ve been slacking on installing but I bought it for this noise because I’ve also Heard people say you need aftermarket sway bars when lowered
Silverplatter
Jan 15, 2022 01:39 AM
future62
Feb 12, 2018 05:39 AM
hockeyzbh
Aug 23, 2017 11:39 AM
the93owner
Feb 23, 2017 05:30 AM
