Need advice on changing these "rear head water outlet gaskets"
Old Nov 5, 2023 | 12:08 PM
nmendez61's Avatar
nmendez61
So coolant started leaking from these gaskets whats the steps needed to replace them thanks
Old Nov 5, 2023 | 06:07 PM
PhatherPhish's Avatar
PhatherPhish
Here is the procedure from the FSM
I suggest removing your cats as well. The bolts holding them on are going to be a PITA to remove but taking them off will give you much better clearance. Best of luck.
Old Nov 6, 2023 | 03:50 PM
nmendez61's Avatar
nmendez61
Thanks for the advice just got it done
Old Nov 6, 2023 | 11:09 PM
PhatherPhish
How'd it go? Did you end up removing the cats or was there enough clearance to get to everything?
Old Oct 24, 2024 | 11:58 AM
nmendez61's Avatar
nmendez61
No need to remove cats everything can be done on top
Migs87421
Jul 27, 2023 02:08 PM
PNW_IPL
51
Sep 17, 2022 02:14 PM
DustU
Jan 20, 2022 02:18 PM
jhnygz
Oct 24, 2019 09:07 AM
whatthefoie
Apr 21, 2012 08:49 PM
