I need your help for my G37
Old Oct 28, 2023 | 03:21 AM
TROISLITRES's Avatar
TROISLITRES
hello, nice to say I don't speak English perfectly so I will do the best I can. I will need your precious help; unfortunately for an unknown reason my seat on my g37 decided to stop working... the lumbar adjustment still works, the motors used alone with a battery work but mounted on the car, the seats no longer move. Even the memories on the driver's door are not turned on. I checked the fuses and nothing, it stopped working overnight, I don't understand why and of course when I open the door the driver's station no longer moves as usual
If someone has an idea , i'm listening everthing .. here in France we don't have any Infiniti workshop so it makes it even harder.
car : 2011 G37 sedan
Old Oct 28, 2023 | 01:33 PM
dkmura's Avatar
dkmura
20 Year Member
Welcome- when you say "checked the fuses and nothing", which fuse box did you check? Did you also examine the IPDM near the battery? You can also scan for codes held in memory with the BCM.
Old Oct 28, 2023 | 02:06 PM
13_SkylineSedan's Avatar
13_SkylineSedan
Does the passenger seat operate normally? But not even the manual controls on the driver's seat are working?
There is a circuit breaker in the power seat wiring for the driver's side as you can see in the first picture below. It is located near the driver's right knee behind the trim of the center console. I don't know if this item can be "reset" or needs to be replaced but it could possibly be your problem.
However, if you find that is the problem then you need to ask why it blew in the first place so fixing it may not be a permanent solution.
Old Oct 31, 2023 | 09:02 AM
TROISLITRES
Thks for the answer ! I cheked the mini fuse at the pedals and the thoses who are in the hood front right
Old Oct 31, 2023 | 09:04 AM
TROISLITRES
yes ; passenger seat's working
i didn't know about this i have to look ! And i come back to you , but thank you for the clear response
Infiniti7
Feb 5, 2022 10:53 AM
Klaus9
Mar 15, 2021 10:30 AM
G37SBS
May 6, 2011 01:33 PM
Calgarywinger
Car Care & Detailing
13
Aug 11, 2010 10:18 AM
FLGspot
Nov 10, 2007 01:07 PM
