Just a heads-up, but if you are using the sandwich plate as part of an oil cooler set up on the X (AWD) you will need the plate with the angled fittings in order to make routing the lines a reasonable affair.
Here is the one i purchased.
Only issue is you will need to use bonded seal oil washers in place of the o-rings on the nipples where they mate with the adapter plate.
Reason: English is hard....
