High beam/low beam headlights not working
Old Sep 19, 2023 | 10:31 PM
Brightskinned's Avatar
Brightskinned
Hello 👋 everyone I just purchased my 2nd Inifiniti G37s for an everyday car. I noticed that my high beams nor low beams work. Even when though my dashboard shows lights are on and shows blue high beam as well but when I check them out I only see the daylights are on. I hear a clicking from the fuse box when I switch the lights on. I checked the fuses I do not see a blown connector or corrosion. They look good but should I still replace them to be safe or should I check the relay. And if I do is the relay located in the fusible link attached to positive post connected to battery? I have researched and watched almost every YouTube video but no luck. Thanks for the help in advance.
Old Sep 21, 2023 | 12:11 AM
mummy2's Avatar
mummy2
Did you buy new bulbs to see if that's the problem?
Xdeimz
Nov 21, 2022 12:20 AM
Nautical
General Tech Questions
Feb 8, 2021 05:42 PM
diamond
Dec 16, 2017 04:29 PM
G Rated
Feb 17, 2014 09:12 PM
tjc93
Feb 3, 2014 06:20 PM
