Looking to run LED underglow lighting, but need to get the wiring out of the driver side floorboard (tapping a fuse), and into the outside world. Any advice on where I can run the wiring through that's factory?
Once you pull up the sill trim look for 2 (maybe 3) "black tape circles." These are holes that are already cut into the body of the car:
Above image is for passenger but the driver-side will be the same/ similar.
When I ran the OEM security lighting kit, I tapped into the illuminated door sills and passed the wiring through one of those cutouts.
I can confidently say I love you!! I have extra wiring so I can run this through passenger as well if needed! Now I just need to figure out the fuse tapping situation (already have two tapped, the cover struggles to fit back on with the taps sticking out of the slot 😭
