Weird groaning noise when I turn the steering wheel
Old Sep 2, 2023 | 07:45 PM
TheRob's Avatar
TheRob
I'm hoping this is something simple and I'm just an idiot. Suddenly, when I turn the wheel in either direction and put tension on the front, it makes a "groaning" sound. That's the best I can describe it as. Seems when I'm driving straight, I'm hearing a noise from the front that has a slight sound resembling what I'm trying to describe.
Any thoughts of where to start looking? I'm thinking power steering fluid?
Old Sep 3, 2023 | 10:17 AM
socketz67's Avatar
socketz67
Community Builder
Any leaks, low fluid? Maybe there's some air getting into the system? Have you tried replacing the fluid in the resevoir as its fairly simple to do with a $10 harbor frieght pump. I used Wolf's Head Dexron IV ATF last time I did mine.
Good thread here on the topic: https://www.myg37.com/forums/brakes-...g-whine-2.html
Old Sep 3, 2023 | 04:19 PM
TheRob's Avatar
TheRob
Not seeing any leaks. Fluid is near max. So you just pump out what's in the tank and then refill?
How do you get air out of the tank? I'll check that link. Thanks for replying.
Old Sep 3, 2023 | 04:42 PM
socketz67's Avatar
socketz67
Community Builder
I use one of these: https://www.harborfreight.com/multi-...BoCNS8QAvD_BwE
Old Sep 3, 2023 | 04:50 PM
TheRob's Avatar
TheRob
Thanks, headed there now.
Old Sep 3, 2023 | 09:16 PM
TheRob's Avatar
TheRob
They were closed. Hoping they are open for Labor Day and I'll get it and get all the liquid out and start over. Hoping a local parts store has that specific PS fluid, I read in other places that's the best.
It's getting worse so I'm wondering if it's the actual PS pump that's going South. I'll update and I really appreciate your replies.
Old Sep 3, 2023 | 09:26 PM
socketz67's Avatar
socketz67
Community Builder
Harbor Freight should be open on Labor Day? You may also be able to order a similar pump through Amazon prime? Autozone, Walmart, O’Reilly’s, etc should have Dexcom IV fluid.
Old Sep 3, 2023 | 09:30 PM
TheRob's Avatar
TheRob
Banking on all of that. Hoping to get everything local because I don't like the increasing sound and it's seeming to get a little worse. I'm taking turns much lighter now. Praying this fixes it. Will keep you informed.
Old Sep 3, 2023 | 09:47 PM
mummy2's Avatar
mummy2
Loosen the ps cap. Jack the front of the car up so both front wheels are off the ground and turn lock to lock 20 times with the ignition on but without the engine running.
Old Sep 4, 2023 | 01:22 PM
Epiphany's Avatar
Epiphany
You can even use a turkey baster type thing with a small diameter. I used one of those to do change a bottles worth of fluid in my car.
Old Sep 4, 2023 | 06:20 PM
TheRob's Avatar
TheRob
That sounds simple enough. I wasn't able to get to Harbor Freight due to other things today. I'll try this and see if I can just get the air out and go from there. Still want to put new fluid in it. Planning on an entire maintenance this month. Plugs, coils, all fluids. Thanks.
Old Sep 4, 2023 | 07:49 PM
TheRob's Avatar
TheRob
Nice! I can handle that. Thanks.
Old Sep 4, 2023 | 07:50 PM
TheRob's Avatar
TheRob
loll nice. A for creativity!
Old Sep 5, 2023 | 09:58 PM
mummy2's Avatar
mummy2
How do you get air out of the tank? Thanks for replying.
Old Sep 6, 2023 | 10:05 PM
TheRob's Avatar
TheRob
Thank you. I'm assuming the fluid needs to be MAX for it to be considered full? Mine is under the max line and at the minimum line. I haven't been able to get the pump
and fluid yet. I definitely plan on doing it this weekend. It's like the car is groaning at me from something in Lord of the Rings when I turn the wheel at times.
Going to drain it, refill with new fluid, jack up the car and turn the wheel to lock 20 times each and I guess report back. Otherwise, I'm guessing it's the PS pump itself. Going to
check videos to see how easy that is and if I can handle it.
Appreciate your reply.
