No Crank No Start
Old May 21, 2023 | 02:24 PM
moied330's Avatar
moied330
No Crank No Start
hey guys i have a 2012 infiniti g37x. yesterday after installing the grom vline2 unit, my car is completely dead. with a jumper pack the instrument cluster lights up and the radio works but the touch screen does not. i am able to use some radio control thru the steering wheel but that is about it. has anyone run into any issues or something similar when installing the unit or anything in general? any help would be appreciated. thanks
Old May 21, 2023 | 04:29 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Did you double check your connections? Did you ensure that each connector is plugged into its proper location?
As has been discussed, ad nauseam,on this forum, it is very easy to mixup connectors for the AV headunit and the AC amplifier that is mounted to the AV headunit. If your car is "bricked," more often than not the amp is not connected properly.
Old May 21, 2023 | 04:42 PM
moied330's Avatar
moied330
i will look into the connections again. could you possibly link the ad nauseam thing you are talking about, can’t seem to find it. thanks for your help!
Old May 21, 2023 | 04:49 PM
ILM-NC G37S
There are plenty of threads about the amp. However, the following will point you in the right direction:
Post #1 shows what to look for and
Post #2 shows what two connectors SHOULD BE plugged into the amp.
Old May 21, 2023 | 04:59 PM
moied330's Avatar
moied330
ya both of them are plugged in properly. can’t seem to figure out what can be cashing it.
Old May 21, 2023 | 05:04 PM
ILM-NC G37S
And the car still won't crank?
Did you try removing the VLine and go back to stock to see if the car returns to normal?
Old May 21, 2023 | 05:07 PM
moied330's Avatar
moied330
ya changed everything back to stock and still nothing
Old May 21, 2023 | 05:14 PM
ILM-NC G37S
I have to ask, did you do all of this with the battery disconnected?
Did you check all of the fuses?
moied330's Avatar
moied330
ya all the work was done with the battery disconnected and fuses were the first things checked when it didn’t work
Old May 21, 2023 | 05:18 PM
ILM-NC G37S
And you checked ALL of the fuses? Driver-side junction, positive battery link, and IPDM/er?
If you can, snap a pic of the amp for me. And make sure everything back there is fully seated and locked into place. If all checks out then I am out of ideas.... If all you worked on was the center stack with this GROM thing, then the issue has to be there or power related. Perhaps someone else will have some suggestions...
Good luck!
Old May 21, 2023 | 05:22 PM
moied330's Avatar
moied330
And you checked ALL of the fuses? Driver-side junction, positive battery link, and IPDM/er? If all checks out then I am out of ideas.... Perhaps someone else will have some suggestions...
Good luck!
hopefully man lol. appreciate your help
Marmar34
Jul 26, 2022 10:15 PM
jobono69
Mar 29, 2019 11:05 AM
carguy95
General Tech Questions
Sep 18, 2016 10:24 PM
BLKG37xS
Feb 26, 2014 09:43 PM
gcoupe86
Nov 27, 2013 11:01 AM
