Cylinder 3 Misfire/loss of compression
Old Jan 6, 2023 | 12:55 PM
g37dd12's Avatar
g37dd12
All, need your input on an issue for 2012 G37 w/168K miles. I have maintained this car well. 3 weeks ago, got a Catalytic Converter/O2 Sensor Code (forget what number that was). Than a week later, get random misfire and Cylinder 3 Misfire code, engine shakes, knocks and hesitates. I call a mobile master mechanic. He determines that its the coil, puts in a new coil, and encountering same issue, does a compression test. He says that Cylinder 3 has less than 50 lbs of compression. His opinion and advice was: cylinder has gone bad, and it will cost $3K to fix, and that i should dump the car.
Need your advice on if anyone has had this issue and what to do here. Had this car for 6 years. Sad to see it go. Thanks for your help.
Old Jan 10, 2023 | 03:02 PM
projectpanda13's Avatar
projectpanda13
you should ask another mechanic to check. If he's a parts-charger-type mechanic, he's not fully taking his time to diagnosising the car. He could have confirmed the coil pack but swapping it instead of just buying a new one.
granted, for compression, there's not many ways to do it wrong. did he check the other cylinders also?
Old Jan 18, 2023 | 09:04 AM
Rik R.'s Avatar
Rik R.
Completely agree. You are plugging the spark plug and pumping air into a cylinder. If you have significant loss you get to rebuild or replace the engine, no two ways about it.
Good luck,
Rick
Matta_Richard
Apr 9, 2026 04:58 AM
Zachdeg
Jul 31, 2021 07:46 PM
Acftconsultant
Jul 12, 2019 03:44 PM
Glenn2008
Nov 20, 2018 01:21 PM
Jah.37x
Jan 10, 2017 01:27 AM
