Clunking when shifting into drive / reverse from park Fixed by TSB: ITB13-008B
Old Dec 17, 2022 | 01:14 PM
Krzysztof47's Avatar
Krzysztof47
Posting this to help others with this weird issue. A while ago I would get a clunking noise when shifting from park to drive or reverse. Old shop diagnosed it as the rear passenger side CV axle. So I had a brand new OEM one put in and the sound went away. Flash forward to this year I had all wheel bearings replaced and the noise came back. I then had the drivers side rear CV axle replaced with another new OEM unit. That did not get rid of the noise. I knew about the axle TSB, but the thing with the axle TSB is more of a clicking sound and not a clunk. The TSB is also for accelerating or moving, not shifting the transmission into gear from a stationary position. I figured it could not be anything else though as the car has a brand new OEM front and rear driveshaft that were installed correctly as some would say maybe it was the u-joints or something with the diff flanges. I decided to have the axle TSB performed and very importantly to use the special grease the TSB calls for, M77 Molykote grease, nothing else. The noise I would hear was a clunk, not a high pitched click. It would mostly come from the rear and sometimes the front, you could hear it inside and outside the car.
I used new front axle nuts, cotter pins, rear axle nuts, rear spring washers, rear cap adjusters, and cotter pins. The FSM calls for new axle nuts, washers and cotter pins, I just had everything replaced as the cap adjusters can widen from repeated disassembly. I got a small 1oz container of M77 grease:
Amazon Amazon
I had this TSB performed, everything torqued to spec (rear axle nuts have a torque range, very important) and proper amount of M77 grease applied to the CV axle grease flange seals. I had leftover paste after all four axles, so this small jar is more than enough. After the TSB was performed no more clunking at all!!!!
My car is a 2011 G37X Sedan, these are the parts I used for my VIN:
40262-2Y00A (Front Axle Nuts, 2X)
40073-0L700 (Front and Rear Cotter Pins, 4X)
40262-1CA0A (Rear Axle Nuts, 2X) VERY IMPORTANT, THE REAR USE A DIFFERENT AXLE NUT, IT WAS THIS PART NUMBER FOR ME.
40037-1CA0A (Rear Spring Washers, 2X)
40263-1CA0A (Rear Axle Cap Adjusters, 2X)
Hope this helps someone.
Old Dec 18, 2022 | 02:13 PM
socketz67's Avatar
socketz67
Community Builder
Excellent post Krzysztof47. I put this off for a year or so (two different dealers told me that it's harmless), then finally decided to have the dealer do the work last year when I was having some other work done. The annoying "clicking" sound has not returned.
Old Dec 20, 2022 | 09:30 AM
Krzysztof47
Thank you. That's good you were able to get that corrected. The thing with mine was the sound was a "clunk" and not a click, which is why I did not try the axle TSB right away.
OldG2NewG
60
Jun 11, 2020 11:43 AM
petemo94
13
Feb 17, 2020 09:24 PM
