2013 G37xS - Interior lights just stopped working
Old Jun 19, 2022 | 05:58 PM
Maxell's Avatar
Maxell
Question 2013 G37xS - Interior lights just stopped working
Hello,
My interior lights just stopped working one day. All other lights work except trunk light.
Checked all fuses no luck.
Any help suggestions / appreciated.
Thanks,
Max
Old Jun 20, 2022 | 09:29 AM
ILM-NC G37S's Avatar
ILM-NC G37S
What interior lights? The map and door "puddle" lights? Or the nighttime interior "illumination."
Old Jun 20, 2022 | 09:59 AM
Maxell's Avatar
Maxell
Yes, all the interior lights (door, map, door sill plates, puddle, trunk light, etc) stopped working,
Old Jun 20, 2022 | 12:15 PM
ILM-NC G37S
Did you also check the fuses in the IPDM/er- this is the large fuse box located next to the battery behind the fender...? There is a 10amp fuse- should be marked as "TAIL/ILLUMI-" that you should check.
Old Jun 20, 2022 | 12:52 PM
Maxell's Avatar
Maxell
Yes, I did do a visual on those fuses but did not realize that they were responsible for the interior lighting?
I will need to remove the battery to inspect properly.
When I checked the fuses by the drivers side lower panel (next to feet) I used a meter to check continuity.
Old Jun 20, 2022 | 01:08 PM
ILM-NC G37S
Fuse #53 (10amp) marked "TAIL/ ILLUMI" in the IPDM/er also includes the interior, nighttime illumination function.
When the main headlamps are turned ON, the tail lamp relay also gets switched ON (to power the rear tail lights). The interior illumination gets its switching signal from the same relay.
Old Jun 20, 2022 | 04:34 PM
Maxell's Avatar
Maxell
ok, are you thinking it's the relay or fuse or both?
All the headlights, rear / tail lights, etc work - only the interior and trunk lights do not.
Old Jun 20, 2022 | 04:59 PM
ILM-NC G37S
I would check the fuse with a multimeter. If that checks good, then you have to start checking wiring from that junction forward.
As a side note, did you check the BCM area for any water leaks?
Also, if you haven't already, download the factory manual for your specific car from here. You will need sections INL (Interior Lighting) and PG (Power & Ground) though I highly recommend you download the whole manual while it is still available.
Old Jun 20, 2022 | 05:06 PM
Maxell's Avatar
Maxell
ok, I will check the fuse with a meter.
It's just strange that all my lights work (dash, head unit / nav, exterior, etc) except interior lights & trunk.
I have read the dealer has a Nissan Consult tool that can check the BCM?
I do see individual pieces of the manual to download but not seeing a link for the entire manual.
Any help / suggestions appreciated.
Old Jun 20, 2022 | 10:50 PM
13_SkylineSedan's Avatar
13_SkylineSedan
Here's your Interior Lighting System FSM:
https://www.nicoclub.com/service-man...2013%2FINL.pdf
Scroll down below that window and you can "click here to download a copy".
Or from here:
https://www.nicoclub.com/infiniti-service-manuals
Click "G35/G37/Q40", then click "G37", then "sedan", then "2013" and you are presented with the entire collection. "Power Supply, Ground and Circuit Elements" is the power and ground scheme for your entire car including wiring harness and connector info. It takes some decoding but all the info you should ever need is in these books - with thanks to the NICO club for keeping them available.
Old Jun 21, 2022 | 09:13 AM
ILM-NC G37S
re: FSM... you will have to download each section individually (if you haven't already).
If none of the interior lights are working (Puddle, Map, Visor (vanity), or trunk) then the issue is with the BCM as that provides power and ground to those components. If fuses are good it could be a ground connection. It is just a matter of going through the wiring diagrams and checking everything step-by-step.
Side note, have you checked for any water leaks around the BCM area? Have you checked that all connectors are clean and tight? This is a known issue with these cars...
Old Jun 21, 2022 | 09:27 PM
Maxell's Avatar
Maxell
ok, do you know if the Nissan Consult tool will read the BCM for these type of issues?
Old Jun 21, 2022 | 10:58 PM
ILM-NC G37S
All CONSULT can do is individually "toggle" each circuit to determine a good/ no good condition. CONSULT will not tell you if there is a bad ground/ other wiring issue. It may be able to call up any BCM-specific trouble (fault) codes but in the end there is no substitution for hands-on testing of power, ground, continuity, etc.
All of this is documented in section INL of the factory manual that both 13_SkylineSedan and myself referenced above. With these type of electrical gremlins, there often is no "easy fix."
Old Jun 24, 2022 | 09:30 PM
Maxell's Avatar
Maxell
It's almost like a lost all power the all of the interior lighting - very strange.
I have started looking thru the manual. It would be nice to see what the Consult Tool shows...
Old Jun 28, 2022 | 04:52 PM
Maxell's Avatar
Maxell
So it looks like I have some corroded terminals on my BCM.
Does anyone know if the BCM is unique to the car?
Thanks,
