Passenger side cooling fan not working
Old Apr 17, 2022 | 07:54 PM
JDW2010's Avatar
JDW2010
HELP ANYONE I have a 2010 G37 sedan I replaced the fan assembly and the passenger side fan does come on at anytime. Checked for power from the control module and their is power going to the fan when the AC is on but the fan isn’t starting I checked the fan before I installed it and it was working am I missing something. I used a test light to see that their was power to the fan?
Old Apr 19, 2022 | 09:16 AM
13_SkylineSedan's Avatar
13_SkylineSedan
Are you talking about the AC blower fan located behind the glove box? There's only one for the whole car. And I'm pretty sure the air ducts to the driver and passenger side split left and right after the duct shutoff valves (or whatever they're called). So the only way to have air flowing on the driver's side and not on the passenger's side is to manually shut off the air vents on the dashboard using the flow control at the bottom of each vent. For example, you can't individually control the foot or defrost vents, they always run "in stereo". Let me know if I'm misunderstanding your question.
Old Apr 19, 2022 | 10:08 AM
ILM-NC G37S's Avatar
ILM-NC G37S
I think OP is referring to the front radiator/ AC condenser fans...?
If so, OP, check this thread as it has the instructions to run IPDM/er self-test- which includes both front fans (fan motors, module, relay).
If not, disregard, clarify and advise...
Old Apr 19, 2022 | 10:15 PM
13_SkylineSedan
D'OH! OK, that makes more sense. The two radiator cooling fans ... as shown in the Engine Cooling System FSM:
https://www.nicoclub.com/service-man...F2010%2FCO.pdf
Click "download a copy" below that main window.
I don't think those fans are meant to work independently, aren't they supposed to both come on at the same time? Though they are plugged into a "cooling fan control module"...
OK, I'll shut up now and wait for the OP to straighten us out.
Old May 17, 2022 | 02:37 PM
JDW2010's Avatar
JDW2010
Thanks for the input
Thanks to all who replied I was talking about the cooling fan on the passenger side of the radiator I have downloaded the manual and ill try to trouble shoot it.
Old May 4, 2023 | 01:11 PM
GP1200ss's Avatar
GP1200ss
Hello Everyone,
Hope someone found a solution. I had to bypass my fan module and relay. My IPDM test on fans was hit and miss. Replaced IPDM with hopes but fan test is still hit or miss. I have an 08 G37 with 160k miles. I now realize since I got the car w 80k miles the 2 fans had never worked I never heard them on high speed. Suspect a bad ground somewhere. Hope we can revive this topic.
Thanks
JB
SamL11B
General Tech Questions
Aug 1, 2021 10:09 AM
ZoeInfiniti
May 17, 2021 11:18 PM
Crunk
G37 Convertible
Apr 12, 2021 03:51 PM
WG37s
Jul 27, 2020 08:26 PM
mtscanlon
Dec 12, 2010 04:19 PM
