Belt Tensioner
Old Mar 4, 2022 | 05:45 PM
mongo312's Avatar
mongo312
Belt Tensioner
Has anyone replaced the belt tensioner without removing the fans? Can't get a ratchet on the bolt head because of how close the fans are. Could remove the bolt with a wrench but then how do you torque it on reassembly? Belt looks remarkably good after 131000 miles.
Old Mar 4, 2022 | 08:55 PM
mongo312's Avatar
mongo312
My neighbor has a set of crowsfeet wrenches that gave me enough room to get on the bolt. Never heard of them before. But his wrenches are so worn out that it rounded off the bolt head. Ended up taking off the bolt with a ratchet wrench. The new bolt fit the crowsfeet wrench perfectly so I was able to torque it properly.
Old Mar 5, 2022 | 12:42 PM
Ponyryd's Avatar
Ponyryd
Did mine from the bottom with a wrench, torqued it till I thought it was tight, lol.
Old Mar 5, 2022 | 07:01 PM
MK11's Avatar
MK11
I researched that you can drop the fan a little to get the clearance instead of actually removing the whole thing. ( I have to replace my Power Steering and that was what i researched i can do so it may work for the tensioner although it is lower so I'm not sure)
Old Mar 5, 2022 | 09:42 PM
x818ray's Avatar
x818ray
offset box wrench is what i used. i did have to add an extension for leverage. i used a pipe.
Old Mar 5, 2022 | 11:48 PM
spoolin03's Avatar
spoolin03
Those crow feet wrenches will come in handy. I used them to tighten my HFC bolts when I didn't have enough clearance with the other choices. Got them cheap at the cheap hardware store.
RicardoV36
Aug 20, 2020 11:34 AM
Joyryde
12
Dec 27, 2019 01:35 PM
g37_black
General Tech Questions
Mar 12, 2019 09:45 PM
killa j
Aug 16, 2014 10:46 PM
