automatic vs manual sedan driveshaft
looking to manual swap my 7at sedan, is there any way to modify the automatic driveshaft to work with a manual transmission or is the only way around it to get one for a manual?
also the differential, pretty sure theyre different
update: found a thread with this video in it
he saying the coupe and sedan driveshafts are the same lengths, so i might just go with a coupe 6mt oem driveshaft because it is cheap and if it fits ill probably order a 1 piece. i also seen a video of someone doing a g35 6mt swap and they just took the collar off the 5at driveshaft and it worked with the 6mt trans so i guess i will try that as well cant hurt ill probably have to end up getting a custom one anyway
and z1 sells a flange for the diff to convert it to the 6mt one if i have to go that route
