Help me identify this noise
Old Jan 24, 2022 | 01:29 PM
Avery Madrigal's Avatar
Avery Madrigal
Idk what is causing this noise but I've been hearing it a lot but don't know where it's coming from any suggestions?
File Type: mov
Old Jan 24, 2022 | 02:59 PM
BULL's Avatar
BULL
Moderador
Sounds like a pump whining noise. I usually hear mines when I'm low on gas.
Fill her up and see if you notice it.
Another thing that could make this noise is pin holes in the exhaust.
Both are non concerning and will get worse with time, pointing you in the right direction.
Old Jan 24, 2022 | 03:05 PM
Avery Madrigal
its like that all the time regardless of how much I have in the tank and can you explain more on the pin holes ?
Old Jan 24, 2022 | 08:22 PM
fuze01's Avatar
fuze01
The hissing-like noise? My car does it as well I thought for sure I had an exhaust leak.. Have not gotten to diagnosing it yet.
Old Jan 24, 2022 | 08:48 PM
Avery Madrigal
that's what I'm thinking too but let me know when you find out first
Old Jan 24, 2022 | 09:47 PM
fuze01's Avatar
fuze01
Waiting for warming weather but plug 1 of your exhaust pipe and blow air on the other pipe using a shop vac, then spray soap around your y-pipe as I hear it is common for them to rust first. Look for air bubbles.
Old Jan 25, 2022 | 10:03 AM
BULL's Avatar
BULL
Moderador
This is a great advice, it will keep the soapy water from evaporating as well as introducing enough pressure to show leaks if there are any.
Old Jan 27, 2022 | 10:02 AM
twin_snails's Avatar
twin_snails
It sounds like a hissing catalytic converter to me. Possibly just needs new gaskets and to be tightened up.
rotarylvr
Apr 13, 2011 09:15 PM
like_a_g37
Apr 1, 2011 06:16 AM
Hotrodder00
Jan 8, 2011 09:48 PM
GregUMR
Car Care & Detailing
14
Dec 29, 2007 08:18 PM
