2012 G37X sedan Exhaust Cutout
Old Aug 10, 2021 | 12:29 AM
G37HVN8's Avatar
G37HVN8
Hi everyone, this is my first time posting here but after weeks of searching I'm sending out an S.O.S. Recently I've begun adding a few simple mods that don't break the bank. Call it a budget build. Anyways, I received an electronic exhaust cutout and need help with wiring specifically trim removal and finding the idel location to install the rocker switch that controls the exhaust cutout. I'm modeling this mod off of a video I saw on YouTube: https://youtu.be/rsWkOWGme6A
The center console varies slightly from the one on my own G. And I can't figure out how to remove the console without pulling apart the shifter. Any advice or other ideas for where to mount the switch and wire everything? Thanks a bunch.
-Justin
Old Aug 10, 2021 | 01:08 AM
spoolin03's Avatar
spoolin03
There's a panel next to your left foot when you're in the driver's seat. Just use one of the (12 volt?) fuses to power the cutout and also put the switch in the dash near that area. Main thing is that there is a power source by your foot. Don't need to mess with the center console, because you're gonna jank **** up.
Old Aug 10, 2021 | 01:13 AM
spoolin03's Avatar
spoolin03
You're going to have to use the internet to find out the voltages between each fuse, and go with the one that matches the required voltage of the cutout.
Then go to autozone and pick up one of those fuse doubler adapters (allows you to branch off from a fuse location) and connect your cutout wiring, including the switch wiring, to that. Add a fuse in that adapter for your cutout to be safe.
Or just take it to a sound shop for the wiring.
Old Aug 10, 2021 | 01:14 AM
spoolin03's Avatar
spoolin03
What kind of cutout setup are you doing? I was thinking of doing cutouts, but was looking at the pressure activated ones.
Old Aug 10, 2021 | 01:18 AM
G37HVN8's Avatar
G37HVN8
I'm running the granatelli cutout: https://granatellimotorsports.com/i-30499981-granatelli-motorsports-electronic-exhaust-cutout-kit-307525.html
Mounting between the cats and the resonators in the y-pipe. And I thought about tapping into the fuse box but I'm not sure where I'd drill under the car to run the wiring.
Old Aug 10, 2021 | 01:20 AM
G37HVN8's Avatar
G37HVN8
Also with the fuse double adapter, would I still need to connect to grond somewhere along the floor?
Old Aug 10, 2021 | 01:46 AM
spoolin03's Avatar
spoolin03
Yes. The fuse adapter is not required but it just makes it cleaner, and you can tap into lines that become active when say you turn the ignition or you could tap into a line that stays active at all times. Try googling fuse box locations for your car or search through the service manual here:
https://www.nicoclub.com/infiniti-service-manuals
Yes ground to complete the circuit. I believe the manual shows grounding points? I know there's one behind the stereo. You could use a multi-meter to check voltage to confirm ground.
I would take it to a trusted stereo shop to wire it for you. Headache and time saved is well worth the money
G37HVN8
Aug 10, 2021 12:25 AM
Casey Hudak
Sep 1, 2019 05:36 PM
MotorvateDIY
Jun 18, 2017 08:42 PM
Awakence
MODDING 411
Mar 30, 2015 10:13 AM
TeRRoRiFiC35
Intake and Exhaust
24
Jun 28, 2011 03:48 PM
