driver side key cover
Old May 27, 2021 | 01:40 PM
AnotherVQ's Avatar
AnotherVQ
"Keyhole Escutcheon"
Driver: (p/n: 80646-xxxxx) has hole for key:
Passenger: (p/n: 82646-xxxxx) solid cap:
The right (passenger) side door handle does NOT have a lock cylinder which is why a solid cap was used instead of a "key hole" cap.
Technically, the right side (solid) cover will fit the left (keyhole) side. Many (myself included) have ordered the right side cap to replace/ "delete" the left key hole- makes for a cleaner line, IMO at least.
You can order whichever one you want- subject to availability in your paint code or search for used on eBay.
Thanks. So if I do this I! Lose the option to use the keyhole?
Old May 27, 2021 | 01:49 PM
ILM-NC G37S's Avatar
ILM-NC G37S
If you do the keyhole "delete" and, in the (unlikely) event that your fob battery completely dies and you find yourself "locked out," you would have to pop off the cover and use your mechanical key.
If this seems too daunting, or you are routinely in the habit of using the mechanical key, then I would suggest you just get the regular cap with the key hole and call it a day.
Old May 27, 2021 | 01:59 PM
AnotherVQ's Avatar
AnotherVQ
So the cap that covers the hole doesn't remove functionality
Old May 27, 2021 | 02:04 PM
iCrap's Avatar
iCrap
No, literally just a cosmetic cover. It's very easy to remove if the battery dies. (infact, i had to do it once because I didn't use my car for a long time and it died)
Old May 27, 2021 | 02:12 PM
AnotherVQ's Avatar
AnotherVQ
Thanks, so this should be the white one I need: https://www.discountinfinitiparts.co...eon-82646ju80a
Old May 27, 2021 | 02:15 PM
iCrap's Avatar
iCrap
Yep looks right. Price must have gone up... I paid like $25.
coolcar37
Feb 16, 2024 12:09 PM
clx
May 19, 2014 02:01 AM
08G37S
19
Aug 10, 2013 08:08 PM
pdarby
Oct 11, 2008 06:51 PM
