Help - engine knock problem
Old Jan 31, 2021 | 10:40 PM
Jr078's Avatar
Jr078
Currently had a rod knock due to running w no oil and after swapping the engine (2012 g37 3.7 journey) for a newer year but same model.. 2013 3.7 g37 journey I came across these problems.. I would appreciate any help that can lead me towards the solution.. I’m in a need to finish the car ASAP as it was my daily for work. Thanks in advance
Old Mar 4, 2021 | 08:58 PM
cumron's Avatar
cumron
did you ever figure this out? my 2013 is knocking and barley responding to throttle. restart the car it acts like nothing happened
Old Mar 4, 2021 | 09:39 PM
crookncastle's Avatar
crookncastle
i'm thinking the cam sprocket has slipped. the adjuster is not able to bring it back onto time. how well do you take car of your ride, meaning interval of oil change? do you use quality oil or just whatever is cheapest off the shelf or oil change special? how did you run the engine out of oil, negligence or oil leaks?
C@ciQ
Intake and Exhaust
30
May 23, 2009 07:14 PM
Blackjack
Picture Share G Coupe
69
Jan 12, 2009 07:42 PM
