How important is the rear plastic undertray?
I really need to get to my evap canister so I can get rid of the permanent CEL but all the bolts seem rusted and seized.
Yes, those small 10mm bolts are very easy to snap. If you do get any out, I would put anti-seize on the threads to make it easier later.
I do this for almost every bolt I remove.
I suspect the rear cover helps to direct air under the car and around the bumper. With out it, a large cavity is exposed which might "catch" the air flow, but I don't think you would notice any difference.
