Help troubleshooting a battery/power problem
Old May 9, 2020 | 02:46 PM
clouser's Avatar
clouser
2012 G37x sedan
Car sat for 2 weeks due to COVID, battery was dead, got a jump, and was fine
Car sat for 3 days, battery dead again, second jump, this time went and bought new battery
New battery installed, car starts right up.
Next day, battery dead AGAIN
Use a 12V charger, nothing I do gets the new battery to work (50V quick start, 10V long charge of 3+ hours)
Use the 12V charger to charge up the old battery, starts up just fine
Both new and old batteries show ~ 12.6V out of the car, and seem to hold charge outside the car
Old battery in car with engine running only shows ~ 13.2V, even when revving engine, I would have expected to see ~ 13.6v idle and 14v+ when revving
Ran the car for about an hour, then turned car off. Old battery was down from 12.6V to 12.25V, meaning close to 50% battery drain
Am I at alternator replacement or is there anything else I can try?
Old May 9, 2020 | 04:00 PM
stealthee's Avatar
stealthee
Do a parasitic draw test. A bad alternator will not kill a battery when the car sits.
Old May 9, 2020 | 04:46 PM
juster's Avatar
juster
Seems simple but make sure terminals to battery are clean and tight.
Old May 9, 2020 | 07:57 PM
clouser's Avatar
clouser
As soon as the weather is nicer tomorrow I'll be doing this.
Old May 9, 2020 | 07:58 PM
clouser's Avatar
clouser
Yep I re-tightened everything and also cleared off most of the corrosion to improve the contacts, so I think I am ok there.
Old Jul 4, 2022 | 01:48 PM
mongo312's Avatar
mongo312
Were you ever able to resolve this? I am having the same issues on my 2011x sedan. 13.2 volts with the engine running. Thought it should be higher. Could the ecm be constraining the voltage too low? Looking up alternator testing now to see if a replacement is in my future.
Kampuchea_G
General Tech Questions
Jul 31, 2017 06:04 AM
tite_tite
Jan 7, 2016 12:09 AM
inyquest
Aug 1, 2013 12:13 AM
sculhane
Dec 12, 2009 12:56 PM
C@ciQ
33
Mar 21, 2009 03:56 PM
