Diff Bushing Blew
Old Apr 24, 2020 | 06:54 PM
Mojo_Dp's Avatar
Mojo_Dp
Diff Bushing Blew
Went to my friends shop for an oil change and saw the beautiful sign of oil on the diff case and exhaust. Heard this is a massive pain in the *** and super expensive to fix.Should I even attempt to fix it? would a diff brace be able to help a bit?
Old Apr 24, 2020 | 08:16 PM
GDriveAlot's Avatar
GDriveAlot
Old Apr 24, 2020 | 09:37 PM
rks's Avatar
rks
Doesn't hurt to try the epoxy fill first. Mine would thump loudly with gear changes so I had the bushing replaced along.with installing the Bell brace. I haven't pushed it yet but normally.any aggressive acceleration resulted in severe wheel hop.
Old Apr 24, 2020 | 11:36 PM
iCrap's Avatar
iCrap
Mine blew, i put the diff brace in and noticed a HUGE difference. Then I did the epoxy fix and got even better. Wheel hop gone, as well as the huge THUNK i would have when it changed gears at WOT. I'm not going to change the bushing... not worth it at this point imo.
Old Apr 25, 2020 | 07:14 AM
Accept the situation, and appreciate the opportunity for upgrade with aftermarket diff bushings. In the meantime, try the epoky fix, then start planning and saving for the repair.
I certainly wouldn't recommend the diff brace with sloppy mounts.
Old Apr 25, 2020 | 03:02 PM
iCrap's Avatar
iCrap
^ I dunno about that. The diff brace made a huge difference even with the blown bushing - and totally could be used as a temporary fix while you wait to get the bushing fixed in the future. Plus its a 10 minute install.
Maybe when I get my lift installed I'll attempt replacing the bushing, but for now epoxy fix + diff brace seems to be holding up well.
Old Apr 25, 2020 | 04:24 PM
I don't know, could be totally fine. But I wouldn't do it. Maybe if Bell says "heck yeah, no problem."
Ask him.
Old Apr 25, 2020 | 06:46 PM
ryanwhite74115's Avatar
ryanwhite74115
Just get the Z1 removal tool if you are brave enough to try it yourself. My mechanic loved it so much he bought it from me haha.
Old Apr 25, 2020 | 09:24 PM
Mojo_Dp's Avatar
Mojo_Dp
I dont really have a lot of wheel hop maybe bc im awd. So ill give it a go
Old Apr 25, 2020 | 09:26 PM
Mojo_Dp's Avatar
Mojo_Dp
My buddy has a nitrious fbo g35s, that he beats on everyday, all he did was a brace and it made a difference for him, guess ill order one up.
Old Apr 26, 2020 | 08:39 PM
Atl3128's Avatar
Atl3128
My rear diff bushing went out a while back so I went ahead and did a 3.69 VLSD swap along with white line bushings. It was a pretty straight forward install took me about 3 hours for both. I used a sawzall to cut out the bushing an a big C clamp and piece of flat bar steel to press the new bushing in. The car definitely feels more planted especially on hard take off and very little vibration during normal driving. Still thinking about getting the diff brace as well.
heedtheninja67
South
Nov 4, 2020 08:44 PM
TuckerE36
Sep 5, 2019 10:42 AM
JT2014
12
Oct 30, 2018 01:25 AM
ryanwhite74115
19
Jul 8, 2017 08:48 AM
TreeFiddy
Dec 29, 2015 04:50 PM
