Quarantine Projects
Old May 23, 2020 | 06:21 PM
  #196
4DRZ's Avatar
4DRZ
Originally Posted by TheDevilsG
whiteline diff bushings, rear diff brace in. KWs, spl rear camber arms, toe bolts, eccentric lockout bolts going in stat!
Future plans for some spl upper front caster/camber arms, some hotchkis and soul function bracing love too... and more to decide on. Operation handling is a go! 😁
What kind of KW's are those? I am curious to hear what you think of the ride and performance.
Originally Posted by jfridge92
Lol which ones did you use to replace yours, just so I know which ones to avoid
If/when these break, I'll probably just pony up and throw whiteline's on the car and call it good.
I had Moog originally, but like iCrap said- they don't seem to hold up much better. I have SPL now and they seem to work well. No problems so far.
Old May 23, 2020 | 08:25 PM
  #197
TheDevilsG's Avatar
TheDevilsG
[QUOTE=4DRZ;4274040]What kind of KW's are those? I am curious to hear what you think of the ride and performance.
These are the KW v1s. Im starting with these and want to get all the other suspension bits in. Then when im done with all the other supporting suspension mods on the car later on i may switch over to the V3s and sell these for a cheap price to whoever wants them.
I've talked to someone who tracks one of his cars on v3s and another on v1s. He loves them both. The v1s are apparently incredibly well made, they just don't cost 4 grand like the v3s because you can't adjust all the damping and more options.
They are however setup very nice and he seems as content with his v1 car as his v3 car. Just v3 car he can go all adjustment crazy on stiffness and dampening and I'm sure that extra fine tuning is a blast lol
Once i have them on and have enjoyed them for a bit ill be happy to give you some feedback on them.
Old May 24, 2020 | 05:20 PM
  #198
4DRZ's Avatar
4DRZ
[QUOTE=TheDevilsG;4274047]
Sounds good. If you like the ride on the street and think they handle well, let me know when you are done with them. I may be interested. I think I am done with track days with my car.
Old May 24, 2020 | 07:27 PM
  #199
TheDevilsG's Avatar
TheDevilsG
[QUOTE=4DRZ;4274087]
Noooo i like your brake advice and track setup advice, You do not have permissiom to hang up the track gloves! I forbid it!
Old May 24, 2020 | 08:31 PM
  #200
4DRZ's Avatar
4DRZ
[QUOTE=TheDevilsG;4274093]
Don't worry, I'm not going to learn anything more at the track with this car. Still plenty of free advice for anyone who needs it.
Old May 30, 2020 | 10:33 AM
  #201
SonicVQ's Avatar
SonicVQ
Originally Posted by G37sPhoton
My shifter was all scrapped up, so had ordered this cover from eBay and thinking meh...for 4 bucks , what the heck...but it actually does a decent job on covering it up and easy , luckily I had red string from prev steering wheel wrap
Well done!! That looks great.
I have a extra factory shift **** that is torn and will see if I can get a cover like this. Do you remember the seller?
Old May 30, 2020 | 10:46 AM
  #202
SonicVQ's Avatar
SonicVQ
Originally Posted by Dzionassi
How about "performance" oil change with home made purger LOL
That's interesting... I assume the purpose is to use air to push out as much used oil as possible. Any idea how much is pushed out?
After doing this, the oil pump and oil feed lines will have air in them. To prevent a dry start up you can use the "clear flood mode"
Clear Flood Mode:
• Left foot on the brake or clutch to the floor.
• Right foot holds the accelerator pedal to the floor
• Push start
This mode turns off the fuel injectors and the engine will just crank for about 4-5 seconds at around 250 RPM.
You can use this a few times to build oil pressure, without the engine running.
Old May 30, 2020 | 11:11 AM
  #203
TheDevilsG's Avatar
TheDevilsG
Clear Flood Mode:
• Push start
Dude, thats damn cool! So the days of disconnecting the fuel injecters to feed oil to a fresh/ dry motor are done. Cool tip!
Old May 30, 2020 | 03:12 PM
  #204
Psycho's Avatar
Psycho
Built these bad boys 😍
Old May 30, 2020 | 03:20 PM
  #205
I normally don't like a murdered out front grille, but damn... that looks so-o-o good.
Old May 30, 2020 | 03:35 PM
  #206
stealthee's Avatar
stealthee
I mean, clear flood mode has been around for a long, long time. Most people will still unplug the injectors just in case regardless.
Old May 30, 2020 | 03:38 PM
  #207
Psycho's Avatar
Psycho
Thanks lol sprayed it myself too.. quarantine had me doing all sorts of stuff to my car lol
Old May 30, 2020 | 08:14 PM
  #208
TheDevilsG's Avatar
TheDevilsG
Those of us who were tuning 90s cars before the G sure didn't know about it. New to me lol but yea still probably best to do it the old analog way
Old May 31, 2020 | 09:14 AM
  #209
SonicVQ's Avatar
SonicVQ
One thing to keep in mind is that is doesn't work on all makes.
For example when I tried this on my E39 BMW, the engine started and revved to 5,000 RPM.
Just be careful the first time you try it
Old May 31, 2020 | 01:35 PM
  #210
TheDevilsG's Avatar
TheDevilsG
Maybe your Bmw is just a rebel lol
